I do not have a copy of Uniform Plumbing Code. Section 1209.5 lists acceptable gas piping materials and joining methods.
Is copper and brass allowed? The situation I am researching is low hydrogen sulfide (less than .3 grams of hydrogen sulfide) and dry (no drip legs required by gas supplier) I know many AHJ do not allow copper and they forbid such with local amendments. What does the unamended code allow? |
John...would the 2003 IRC requirements suffice or do you need the UPC as stated? If the IRC is acceptable then I'll transcribe what G2414.5.2 says about copper tubing.
I also have a question in to San Antonio code department. Per San Antonio gas provider: They have less than .3 hydrogen sulfide Gas is dry; drip legs not required. |
2003 IRC G2414.5.2 (403.5.2) Copper tubing. Copper tubing shall comply with standard Type K or L of ASTM B 88 or ASTM B 280.
Copper and brass tubing shall not be used if the gas contains more than an average of 0.3 grains of hydrogen sulfide per 100 standard cubic feet of gas (0.7 milligrams per 100 liters). |
Hi. John;
NFPA 54 will approve the use of copper and brass as long as the gas does not contain more than 0.3 grains of hydrogen sulfide per 100 scf of gas. Other alternatives would be steel and wrought Iron. There are other types of piping available for this use. Alluminum alloy pipe shall not be used in exterior locations or underground. I would definetly check with the local gas company in a particular jurisdiction as to what can be or will be approved in that area. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
2006 International Fuel Gas Code:
Knowledge is power, but sharing knowledge brings peace! http://www.psinspection.com TREC License# 7593 Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC! Last edited by escanlan; 6/26/07 at 7:35 PM.. |
Thanks all. Gas supplier wrote to me their gas is .25 or less. Thats less than .3. No special amendment in SA code. Looks like it can be used. Will wait for reply from city.
Will post more as I find out. Manny, No EW at this time. |
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 41 | 4/5/12 6:43 AM |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 8:16 AM |
| Identify ABS defective pipe | mcyr | Plumbing Inspections | 6 | 1/29/09 6:39 PM |
| green crystallized matter on copper pipe | Scott Schultz | Plumbing Inspections | 5 | 10/17/07 3:30 PM |
| Looking for comment by Caoimhín P. Connell | phinsperger | Ancillary Inspection Services & Additional Topics | 2 | 2/18/06 11:22 AM |
