Old 3/26/07, 7:53 PM
Richard Seay Richard Seay is offline
Please Note: Richard Seay is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Copper Line Fitting
Is this fitting appropriate for copper pipes? I found it on supply line to water heater.
Old 3/27/07, 7:06 AM
ckratzer ckratzer is offline
Please Note: ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Copper Line Fitting
A brass compression fitting would have been better.
Sweated fittings would have been best but the repair person was probably afraid they would burn the house down.Pretty close quarters to use a torch in.
Old 3/27/07, 7:25 AM
Ian Gills Ian Gills is offline
Please Note: Ian Gills is a non-member guest and is in no way affiliated with InterNACHI or its members.
I do not like the steel strap on the copper pipe. That could cause corrosion.
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Oxidation on Copper Gas Line jfunderburk Inspecting HVAC Systems 35 1/10/07 11:13 AM
Bathroom Shut-off Valves - Mineral deposits - Do you note them as leaking in reports? jwatts1 Plumbing Inspections 8 7/29/06 11:50 AM
TPRV line and condensate line marriage ccarrington Plumbing Inspections 3 4/29/06 7:59 AM
Looking for comment by Caoimhín P. Connell phinsperger Ancillary Inspection Services & Additional Topics 2 2/18/06 11:22 AM
