Had a propane tank today. Supply was flexible copper ran to house underground then converted to black pipe from there on. Can flexible copper be ran underground for propane?
Andrew Dooley Dooley Home Inspections LLC Broken Arrow, OK 918-955-0525 andrew@dooleyinspections.com |
The propane supplier usually runs the line from the tank to the house here. |
Andrew,
Same thing, the PLBG.Contr. or HVAC Contr. usually runs Black Iron pipe from various appliances to building edge, stubbed out with pressure guage on. The LP supplier locates Tank (usually above ground and within 20'-25' of foundation and/or connection) and runs copper underground (min.18" below) and makes final connection, fills and test fires lines and appliance(s) before either shutting back down or leave operational, depending on local inspection requirements. |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
| Flexible copper tubing carrying propane at interior, OK? | kshepard | Plumbing Inspections | 1 | 3/3/07 2:24 AM |
| Bathroom Shut-off Valves - Mineral deposits - Do you note them as leaking in reports? | jwatts1 | Plumbing Inspections | 8 | 7/29/06 12:50 PM |
| supply in slab or walls? | jeubank | Plumbing Inspections | 1 | 7/8/06 11:36 AM |
| Looking for comment by Caoimhín P. Connell | phinsperger | Ancillary Inspection Services & Additional Topics | 2 | 2/18/06 12:22 PM |
