Would you say anything????
Thanks! Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
| Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I don't see anything here that would cause siphoning or any other problem. What is your concern?
Mark,
Thanks, just the amount of turns. Thanks, again. Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
The IRC and UPC do not allow a double trap (in series) but you can do a separate trap on each sink (in parallel - as shown) joined together in an appropriate wye to the wall.
Thanks! David
The UPC does not allow this installation. Only one trap is allowed on a trap-line. The UPC would require that the two sinks share one trap.
We do it in Wisconsin but with a clean-out between the two wyes.
What code does WI follow?
| correct roof penetration | rperkerewicz | Electrical Inspections | 8 | 1/28/12 11:20 PM |
| Is the correct term for this type of roof | rchorey | Exterior Inspections | 2 | 1/2/09 11:06 PM |
| Correct connect at Furnace | tmartens | Plumbing Inspections | 2 | 5/1/07 9:33 PM |
| First to answer this question substantially correct wins a NACHI Beam. $109 value. | gromicko | Miscellaneous Discussion for Inspectors | 28 | 1/30/07 4:30 PM |
| Is this correct | cpennick | Electrical Inspections | 4 | 6/15/06 10:15 PM |
