Hey Guys-
I was tinkering around in my basement and noticed this corroded fitting on my PEX lines. I put these in about 3 years ago. I remember reading about the Zurn and Uponor issues but was sure it wasn't what I used. But sure enough, when I looked close I found the QPEX stamp on it. And worst of all, it's what I used to redo all my plumbing for my second story bathroom...which I finally got finished and closed up about a year ago. Kenny Rigler Home Inspections Hays, KS 67601 785-656-0272 |
| Need a home inspection in South Carolina? Check out InterNACHI's listing of South Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Nice pictures. I think I would start replacing fittings if this were my home. I certainly wouldn't wait for the class-action suit. A major breach could prove to be catastrophic.
I would get a comprehensive water test to document what you have. I'm not sure if the fittings have any disclaimers about agressive water.
You should replace one asap and then look inside the old one to see how much wall thickness is left. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
And excellent pictures too. |
| Fitting for copper and plastic | dmacy | Plumbing Inspections | 16 | 1/24/11 10:27 PM |
| MJ fitting on ABS | rmisener | Plumbing Inspections | 3 | 2/27/09 5:36 PM |
| Copper Line Fitting | Richard Seay | Plumbing Inspections | 2 | 3/27/07 7:25 AM |
| Flexible Fitting | inspector@carolina.rr.com | Plumbing Inspections | 4 | 6/9/06 8:05 AM |
| Contest! Name that fitting! | jtedesco1 | Electrical Inspections | 20 | 5/30/06 9:16 AM |
