Old 10/28/08, 7:37 PM
David C. Macy's Avatar
David C. Macy David C. Macy is online now
Default Corroded/Rust at main gas pipe
Only a small area of the gas pipe located in the unfinished basement was corroded.
The only thing I could tell was the exterior meter had settled at the seal had broken at the exterior.
There were no other areas of the piping or basement with moisture or corrosion.
What do you think?
Old 10/28/08, 10:53 PM
Brian E. Kelly's Avatar
Default Re: Corroded/Rust at main gas pipe
I think no big deal. If you want you suggest a wire brush and some paint.
Old 10/28/08, 11:08 PM
James F. McKee's Avatar
David....I have a few fittings that look just like that at home...there turned that way shortly after I saturated them with those leak detector bubbles....just a thought....jim
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 10/29/08, 8:39 AM
Thats what I had recommended. Thanks!! Good suggestion.
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 41 4/5/12 6:43 AM
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 1:23 AM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 6:39 PM
