Old 8/4/09, 7:11 PM
Harry McBride's Avatar
Harry McBride Harry McBride is offline
Question Corrosion Gas Supply Piping
Six year old. Let me repeat that SIX year old home. This is the gas supply piping. What in the world would cause this line to corroded this badly in six years? Could it be that it's not even galvanized steel? No gas leaks evident at the inspection. But the connection don't look so hot. Any opinions on this. Gas line is supplying the home and also is connected to a Guardian generator.
corrosion-gas-supply-piping-img_8601.jpg   corrosion-gas-supply-piping-img_8605.jpg
Find an InterNACHI certified North Carolina Home Inspector (and anywhere else in North America)
Old 8/4/09, 7:18 PM
James F. McKee's Avatar
Default Re: Corrosion Gas Supply Piping
You're in Florida Harry ....doesn't it rain every 15 minutes there?...it needs paint....
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 8/4/09, 7:21 PM
That is the only thing I can think of is that they just installed bare galvanized piping with no paint.
Old 8/4/09, 7:25 PM
Black iron pipe rusts.
Jim's right, it needs paint.
Larry Kage, CMI
231 929 3525
Old 8/4/09, 7:27 PM
I ran a black pipe gas line under a sun room open to air about 6 years ago and it looks similar near the fittings where i brushed on the soapy water to check for leaks...i really need to get that thing wire brushed and painted...I'm going to get right to that....uh well maybe a little later ...
Jim Mckee
Amherst, Ohio
Old 8/4/09, 7:30 PM
Wow, you're going whole hog.
Around here the gas guys just paint over the rust.
Larry Kage, CMI
231 929 3525
Old 8/4/09, 7:32 PM
Thanks guys!
Old 8/5/09, 5:43 PM
Brian E. Kelly's Avatar
Surface rust, no biggie. Looks like 3/4" NPT pipe, pretty thick wall on that stuff. Paint it in about twenty years.
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 41 4/5/12 6:43 AM
HELP! What do you call a 3 prong male plug with a cord. gromicko Electrical Inspections 5 1/9/09 12:33 AM
New type of supply piping mnicholet Plumbing Inspections 11 7/17/08 8:32 AM
Natural Gas Supply Piping Into House From Underground cmettel Canadian Inspectors 3 3/1/08 11:09 AM
Bonding Piping 101....Good To Know ! pabernathy Electrical Inspections 37 4/28/07 11:25 AM
