Old 4/27/10, 7:58 PM
Michael J. Meeker's Avatar
Michael J. Meeker Michael J. Meeker is offline
Default Corrosion Issue Need Advice
Hi I thought this was corrosion from dissimilar metal but they appear the same this is my water heater.
What is the cause?
Is there a fix.
Will it cause a leak.
Thanks in advance
Florida Licensed General Contractor
Florida Licensed Home Inspector #299
Wind Mitigation Specialist
Call 954-922-0584 or E-Mail Me For The Best Wind Mitigation Inspection in Florida at a Great Price
Need a home inspection in California? Check out InterNACHI's listing of California certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/27/10, 8:05 PM
Default Re: Corrosion Issue Need Advice
TPR extension blues...
Larry Kage, CMI
231 929 3525
Old 4/27/10, 8:07 PM
Is your water softened?
Larry Kage, CMI
231 929 3525
Old 4/27/10, 8:09 PM
City water so I think it is it is not hard. what is tpr? I have very little knowledge on such stuff.
Old 4/27/10, 8:14 PM
Temperature/Pressure Relief valve
The pipe extension out of it should not reduce in size less than the outlet size of the valve. Yours does. It is a hazard.
Larry Kage, CMI
231 929 3525
Old 4/27/10, 8:19 PM
What is the cause?
Is there a fix.
Thanks in advance
You could clean with the pipes with white vinegar or LCR cleaner.
It's hard to tell but it will be easier to see where the corrosion after cleaning.
Larry Kage, CMI
231 929 3525
Old 4/27/10, 8:20 PM
Jeffrey R. Pope's Avatar
Looks like factory-installed galvanized nipples attached to copper.
The safety issue should be address first. The reduction in the discharge pipe needs to be corrected.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/27/10, 8:29 PM
Brian E. Kelly's Avatar
Fix: New water heater
Old 4/27/10, 8:31 PM
Ok that is not my major concern. The corrosion is. I was pretty sure the relief was wrong you should see the clear tubing it goes to.
Old 4/27/10, 8:34 PM
Do you mean a product called clr?
Old 4/27/10, 8:35 PM
is the galvanized nipples attached to copper what may be causing the corrision?
can it be fixed?
Old 4/27/10, 8:44 PM
It looks like the corrosion is simply due to leaks. The "fix" would be to remove and replace the nipples, but that's not so easy with the rigid connection.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 4/27/10, 8:59 PM
Michael Larson's Avatar
And a real plumber to go with it.
Michael Larson
Hudson, WI
Old 4/27/10, 9:08 PM
Wayne B. Wilson's Avatar
you might to take this course
http://www.nachi.tv/ppv/8
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 4/27/10, 9:13 PM
Sean Fogarty's Avatar
Looks like someones going shopping for a new water heater! Good old FL sulfur water
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Need your advice!!! bgrover Miscellaneous Discussion for Inspectors 28 6/12/08 6:16 PM
Home Inspection Business Part Time (Seeking Advice) Shawn M. Nold General Inspection Discussion 32 9/16/07 11:58 AM
