Old 3/21/09, 4:53 PM
sgarland sgarland is offline
Default Corrosion on new copper?
So I was doing an inspection specifically for a roof leak that took me into the basement to check the chimney and right away I noticed several No Nos in this 2 year old home. The one I am curious about is the excessive amount of corrosion on the copper lines running to the PEX manifolds. There is quite a bit of green, powdery residue on the pipes. What would cause this? I have seen 30+ year old homes with none of this. I would try to post a pic but just imagine a new house with a lot of green corrosion on the small amount of copper. Bad flux? Bad solder? Just didn't wipe excess off?
Find an InterNACHI certified Colorado Home Inspector (and anywhere else in North America)
Old 3/21/09, 5:51 PM
Default Re: Corrosion on new copper?
Hi. Steve; This may help shed some light on that subject.
A Hidden Time Bomb - Corrosion of Piping Systems Causes of Corrosion in a Piping System, Traditional Repair Methods
and the Modern System of Pipe Restoration You can view the rest of the article here;
http://www.hotel-online.com/Neo/News..._TimeBomb.html
Hope this helps a little.
Marcel
Old 3/21/09, 6:31 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Copper can turn green in hours if certain acids come into contact.
if you do not believe me just mix Miracle Grow and water into a paste and brush it on to some copper.
The green may be superficial and black is also no concern in most cases.Just look at any older copper outside the house.
Not saying there for sure is no problem, but it may be nothing.
Old 3/21/09, 6:43 PM
Wayne B. Wilson's Avatar
I have to ask
why would someone come up with this one
Old 3/21/09, 6:51 PM
Jeffrey R. Jonas's Avatar
Originally Posted by wwilson3 View Post
I have to ask
Instant Antiques... an object with the green "patina" is worth considerably more than a "polished" piece.
Old 3/21/09, 6:55 PM
relliott's Avatar
I have to ask
I am an artist and the ability to turn copper green came in handy.
Antique look is often preferable when selling rustic art.
Old 3/21/09, 6:59 PM
Brian E. Kelly's Avatar
Any Chinese drywall in that house??
http://www.canada.com/Health/Toxic+C...648/story.html
Probably did not clean off the flux is my guess, but a picture would help
Old 3/21/09, 8:05 PM
OK i did have to ask
I thought you had slipped into boyhood and where just sitting around thought if i mixed this with that what would it do to copper lol
Old 3/21/09, 8:13 PM
relliott's Avatar
Sounds like me.
When 5 or 6 I was warming corn starch and blowing it through straws into flames just to see if it made a good torch.
Graduated to building small rockets with Estes engines at 11
Old 3/21/09, 8:17 PM
Sounds like me.
A rocket Sceintists turned Home Inspector. Hmmmmmmmmmmmmmm!
Old 3/21/09, 8:27 PM
relliott's Avatar
Hmmmmmmm is right
I wonder what I can do with a Hot Water Tank?
Just kidding of course as next thing I know the FBI will be knocking at my door for being the next Unibomber. haha.
Old 3/21/09, 8:33 PM
Hmmmmmmm is right
I know, I know, I know, break off that little lever on the top and run a couple of blocks down and no one will know.
Old 3/21/09, 8:52 PM
relliott's Avatar
My crazy Uncle said if he ever got mad enough the best way to destroy a building is to pour cement down the plumbing vents.
Imagine the expense.
Old 3/21/09, 8:58 PM
One crazy Uncle Bob.
But before the expense would be can you imagine the smell?
Old 3/21/09, 10:07 PM
relliott's Avatar
Guess those toilets would not flush like they should.
Back when young ,I had a side job in a couple of SRO hotels and all they had were Junkies plus Hookers that would stop up the toilets then wait till the brown was pouring past the top for a month or so before calling me to unplug them.
Had to swat fly's as soon as I opened the door.
Tinned copper & Copper mnahrgang Electrical Inspections 2 3/13/08 7:21 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 9:10 AM
Soldered pipe supports causing corrosion kshepard Plumbing Inspections 7 12/3/06 3:30 PM
Bathroom Shut-off Valves - Mineral deposits - Do you note them as leaking in reports? jwatts1 Plumbing Inspections 8 7/29/06 12:50 PM
Looking for comment by Caoimhín P. Connell phinsperger Ancillary Inspection Services & Additional Topics 2 2/18/06 12:22 PM
