Old 8/9/09, 11:24 PM
Michael J. Merino's Avatar
Michael J. Merino Michael J. Merino is offline
Default Corrugated Drain
Is this type of corrugated drain acceptable?
Michael Merino
Merino's Home Inspection & Education Inc.
"Not just an Inspection, an Education"SM
Phone/Fax 708~535~6057
Find an InterNACHI certified Indiana Home Inspector (and anywhere else in North America)
Old 8/9/09, 11:59 PM
Jeffrey R. Pope's Avatar
Default Re: Corrugated Drain
Absolutely not. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/10/09, 12:19 AM
Thanks for confirming, Jeff.
Michael Merino
Old 8/10/09, 12:54 AM
Besides the fact that these "flex pipes" are not approved for drain lines, the one in your picture is actually intended to be a tail piece (vertical), not a trap arm (horizontal).
Improper use of an improper pipe
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 8/10/09, 1:02 AM
Jeff, it begs the question-If they are not approved for drain lines, then why do they even make them? Why make something that can mess up a system? I agree with you, I didn't like it when I saw it.
Michael Merino
Old 8/10/09, 1:05 AM
Joe Funderburk, CMI's Avatar
Jeff, where is it stated that it's "not approved"? Maybe I need to strengthen my report comment.
All I've ever said about them (if installed as a tailpiece) is this: "The *LOCATION* sink employs an unconventional, flexible, corrugated drainpipe that could contribute to blockages and we do not endorse it."
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 8/10/09, 7:47 AM
David P. Valley's Avatar
Manufacturers make these as universal drain lines. Homeowners purchase these POS because they refuse to spend their hard earned money on a professional installation by a licensed Plumber.
Homeowners all have one thought in mind.....Why waste my money on a Plumber or even measure, cut and glue a smooth walled PVC waste line when I can purchase a flexible waste line that will easily install in minutes and only set me back a few dollars. Leak fixed.
Old 8/10/09, 11:37 AM
Drain/waste lines are not allowed to be corrugated. They must have smooth wall interior, which is why I said "not approved." I'm headed out this morning, so I don't have time to look up the exact code-language.
Here is how I write it;
The *LOCATION* sink employs an unapproved, flexible, corrugated drainpipe that will contribute to blockages and it should be replaced by a qualified plumber.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 8/10/09, 12:44 PM
From the California Plumbing Code and UPC;
PART I – DRAINAGE SYSTEMS
701.0 Materials
701.1
Drainage piping shall be cast iron, galvanized steel, galvanized wrought iron, lead, copper, brass, Schedule 40 ABS DWV, Schedule 40 PVC DWV, extra strength vitrified clay pipe, or other approved materials having a smooth and uniform bore (continued)
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 8/10/09, 1:23 PM
William J. Decker's Avatar
Not allowed in Illinois plumbing code.
There are plenty of materials that are sold which are not allowed.
Romex is sold in the Chicago area when it is not approved.
PVC TPR piping.
Flex drain pipes.
Mini-Breakers (takes up one panel slot, but has two breakers) not allowed in Chicago, but sold.
Exposed bulb light fixtures.
Foil or vinyl clothes dryer vent tubes. In fact, the two largest appliance retailers, around here, always install the dryers with these vent tubes).
Never underestimate the stupidity of the uninformed public, nor the greed of home improvment store owners.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 8/10/09, 1:52 PM
Thanks guys for the code quote.
Theodore Roosevelt
Joe Funderburk, CMI
Old 8/10/09, 2:26 PM
Will, what took you so long to post?
Michael Merino
Old 8/10/09, 9:49 PM
I have been busy doing inspections, writing reports, preparing CE classes and dealing with my youngest, who started drivers ed.
Be afraid! Be VERY afraid!
Will Decker, CMI
Old 8/11/09, 1:09 AM
I am staying off the road!!
Michael Merino
No secondary (pan) drain in Attic Okay per builder mgault Inspecting HVAC Systems 14 1/30/09 9:38 AM
Inspector in hot water after approving unit without drain rcooke Canadian Inspectors 6 2/20/08 4:59 PM
Air leak from floor drain yolhovsky Plumbing Inspections 5 2/24/07 7:43 AM
French drain tied into main drain rwashington Plumbing Inspections 6 2/17/07 12:04 AM
