Old 3/4/07, 12:52 AM
lcapaul's Avatar
lcapaul lcapaul is offline
Please Note: lcapaul is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Csst
Here's an interesting installation of CSST, 30 feet from the meter to the furnace, notice the horizontal drip leg, scary stuff, and you should see the electrical, plus the two racoons in the attic that I didn't have time to get a picture of, vicious little bast*rds, I didn't know I could still move so fast.
ID:	9686 corrugated-stainless-steel-tubing-suc51051-small-.jpg.JPG
ID:	9688 corrugated-stainless-steel-tubing-suc51063-small-.jpg.JPG
Old 3/4/07, 1:28 AM
Charley L. Bottger's Avatar
Default Re: Csst
Attachment 9686 Attachment 9687
Attachment 9688 Attachment 9689
Agreed on drip leg, shut off valve in the wrong place and is that an electrical ground connecting to the gas pipe???
Don't they have insulation for the Ducts up there
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 3/4/07, 9:00 AM
Bruce M. Graham, III's Avatar
Bruce M. Graham, III Bruce M. Graham, III is offline
Default Re: Csst
I like the duct tape conduit strap.
Bungalows to Mansions
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 3/4/07, 9:51 AM
Bruce A. King's Avatar
Default Re: Csst
Also see www.csstsettlement.com
www.BAKingHomeInspections.com
704 301-3207
Old 3/4/07, 1:05 PM
lcapaul's Avatar
Default Re: Csst
You don't need inuslation when one duct blows directly into the basement, and two floor vents are hanging loose and also blowing into the basement, one duct was insulated, asbestos, insulation in this case would be an unnecessary expense.
The furnace was sitting on two concrete blocks, and notice the exhaust vent in contact with the CSST, preheating the Gas must make the furnace more efficient.
As far as the CSST class action, I informed my clients of that, but to me at least some effort to follow the manufacturer's installation guidlines should have been attempted.
This is typical of home in this area, Mullan is an old mining town, pop. 450, most of the houses were built in the 20's for Miners, it's also an area where Code enforcement and permits are not a big priortity when it comes to renovations.
Old 3/4/07, 2:00 PM
Scott A. Figert Scott A. Figert is offline
Default Re: Csst
Was just in a crawl Sat. to repair busted water line (at least 1" water every where). Told the owner I seen a wire splice not in a box and 1 wire was just taped at the end no nuts on it. Shocking if you ask me!!!
CSST Class Action jhagarty Inspecting HVAC Systems 31 1/31/12 1:15 AM
Good CSST document bking General Inspection Discussion 1 11/29/07 1:45 AM
Does anyone know anything about corrugated stainless steel tubing (CSST)? gromicko Structural Inspections 5 9/28/07 7:24 PM
CSST Class Action jcahill Electrical Inspections 1 11/27/06 9:11 AM
CSST gas pipe rtruluck Inspecting HVAC Systems 2 11/14/06 1:48 PM
