Old 3/1/08, 11:05 PM
Bob Elliott's Avatar
Default Is this csst
From todays inspection.
I found this flex coming out of a central feed black pipe with three of these yellow jacketed guys coming off Ts and feeding straight in the walls to appliances.
Is this ok.?
ID:	19107   corrugated-stainless-steel-tubing-dscn4510-small-.jpg.JPG
Old 3/1/08, 11:10 PM
Jeffrey R. Pope's Avatar
Default Re: Is this csst
Yes, that is CSST. It can be used anywhere you would normally see rigid piping (black iron).
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/1/08, 11:15 PM
That was fast .
Thanks.
Is there one not rated for this that looks the same?
Also I do not know if this is common specs , but peoples gas here in Chicago says it should not terminate directly to the appliance.
Know anything about that.
It is referring to movable verses fixed appliances.
Stoves no
furnace or vent less fire place OK
discrepancy for vent less is apparently due to the fact a log could hit it and cause damage.Sound correct.
Sorry for all the questions but I never dealt with this stuff in walls before and I do not feel good about flammables in walls inside flex.
Old 3/1/08, 11:31 PM
IL is an animal of a different color, so there may be some exceptions here, but generally, CSST can be attached directly to appliances, just as with black iron/rigid.
In some jurisdictions, such as CA, a listed appliance connector is still required for most residential applications.
CSST is often confused with "appliance connectors." While they are made from the same or similar materials, they have very different listings and requirements.
Appliance connectors are manufactured in specific lengths with connectors already in place. They are not allowed to pass through walls or appliance cabinets, and cannot be used in concealed locations (within wall cavities or other unaccessible locations) - they are required to be "readily accessible."
CSST piping, on the other hand, can be run in length, through walls and wall cavities, indoors, outdoors, etc., etc., just as you can with steel piping.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/1/08, 11:34 PM
Marc D. Shunk's Avatar
Banned
Correct me if I'm wrong, but I remember right from the TracPipe class I took, CSST is not rated for protection against physical damage. The instructor advised not running it exposed outdoors at or near grade level.
Old 3/1/08, 11:37 PM
ldapkus ldapkus is offline
Robert,
Peoples Gas offers a 2 day gas appliance class that is great. Check it out.
Old 3/1/08, 11:42 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
What's that?
Do they come in copper?
Sorry, couldn't resist!
</IMG></IMG></IMG>
Old 3/1/08, 11:50 PM
Thanks guys .
The answers helped me alot.
From that same peoples gas guide Marc is right about outdoor use.
Yes Linus I know all about the great two day class on the near south side.
Hopefully I will have a good spring and dig up the cash.
Remember I just went full time and counting pennies to keep going.
So far I am way ahead of last year , but I gotta tell you there are easier ways to make money.
Goofy me I choose what I enjoy.
EDIT
Marc here is what you refered to
Old 3/1/08, 11:53 PM
Brian E. Kelly's Avatar
Correct Marc
Old 3/1/08, 11:55 PM
Brian see edit pic post 8
Old 3/2/08, 12:04 AM
You are correct Marc. CSST does require shielding in some applications.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/2/08, 12:05 AM
Still correct Bob.
I beleive we need you to devise a poll on something soon.
Old 3/2/08, 12:20 AM
Ha hah yes I have been thinking of a few good ideas on that line.
I am a frusterated artist and have been working on trying to invent some thing new for the summer fairs in between posting and drumming up inspections.
Old 3/3/08, 10:37 AM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Do all brands of CSST pipe need a BONDING wire install?
Old 3/3/08, 2:34 PM
CSST, as with all metallic gas piping, is required to be bonded to the electrical system of the building. Some CSST will require additional bonding measures or a supplementary grounding electrode.
Jeff Pope
Santa Clarita CA
(661) 212-0738
CSST Class Action jhagarty Inspecting HVAC Systems 31 1/31/12 12:15 AM
Does anyone know anything about corrugated stainless steel tubing (CSST)? gromicko Structural Inspections 5 9/28/07 6:24 PM
CSST Fuel Gas Supply jhagarty Plumbing Inspections 2 4/24/07 10:38 AM
Csst lcapaul Plumbing Inspections 5 3/4/07 1:00 PM
CSST gas pipe rtruluck Inspecting HVAC Systems 2 11/14/06 12:48 PM
