Though the wall? yea or ney
| Need a home inspection in Kentucky? Check out InterNACHI's listing of Kentucky certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
(yea)
Unless being used as flex which it looks like. |
CSST appliance connectors should not pass through walls. CSST distribution piping can.
That is an appliance connector. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Here, the wall must have a sleeve for (CSST dist. pipe) to pass through. Agree, no on the CSST appliance connector. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Its for the stove, thanks guys.
CSST is not allowed to be used directly to an appliance around here either.
Check local code but this is what I have.... CSST is not designed to be used as a flexible gas appliance connector and shall not be used as a substitute. The use of CSST as a final connection for permanently installed appliances, such as water heaters, furnaces, and boilers is allowed. CSST shall terminate outside of the appliance jacket where the excessive heat may ignite or damage the protective coating. The use of CSST as a final connection of movable gas appliances, such as ranges and clothes dryers, is not allowed. CSST shall not be installed outdoors and shall not be run underground unless installed in a sleeve or conduit. www.chicagopropertyinspection.com www.elliotthomeinspection.com www.chicagolandhomeinspection.com www.homeandcondoinspector.com www.homeandcondoinspection.com http://www.homeinspectorpro.com/ (Report Software) Bob Elliott http://www.chicagolandhomeinspector.com/ Last edited by belliott; 3/3/11 at 6:44 PM.. |
Bob , is this a local requirement? I think it can be run outdoors.
David InterNACHI #08051301 NYS Lic. #16000038229 NYS DEC Cert # T4865884 518-505-8305 HouseAbout Home Inspections HouseAbout on Facebook NY Capital Region Chapter InterNACHI |
Yes ,Peoples gas.
| CSST Class Action | jhagarty | Inspecting HVAC Systems | 31 | 1/31/12 12:15 AM |
| Jury Rules That CSST Is a Defective Product in Landmark Case | mboyett | General Inspection Discussion | 9 | 11/3/10 5:01 AM |
| CSST in furnace cabinet | jfunderburk | Plumbing Inspections | 9 | 11/16/08 9:46 PM |
| Does anyone know anything about corrugated stainless steel tubing (CSST)? | gromicko | Structural Inspections | 5 | 9/28/07 6:24 PM |
| CSST gas pipe | rtruluck | Inspecting HVAC Systems | 2 | 11/14/06 12:48 PM |
