Anybody here call this out as a concern? I don't see any mention of clearances in the Gastite Install guide.
Greg Allen,Certified Home Inspector NACHI ID# 05082583 1st Choice Inspection Services, LLC Apex, NC 27502 "Greater Raleigh-Durham Home Inspections and Radon Mitigation Services" http://homeinspectorguy.com "Paying attention to simple little things that most men neglect makes a few men rich" Henry Ford |
| Find an InterNACHI certified North Carolina Home Inspector (and anywhere else in North America) |
Gregory, I don't see much of a problem, when the insulation is installed in the ceiling space, it will isolate the wiring and the CCST pipe.
This is assuming that the recessed can is IC rated of course. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
This is between floors so no insulation will be installed. The light is IC rated. Thanks Marcel!
No problem at all.
What does CSST stand for? First time I've seen the acronym.
Tim |
Tim, CSST stands for Corrugated Staninless Steel Tubing for gas usually. IC stands for Insulated Contact rating for what this thread was about I believe. Hope this helps. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Cheers, Tim |
| Flickering CFL | jallingham | Electrical Inspections | 34 | 12/5/08 3:40 PM |
| Trouble Shooting the Simple Light Bulb | mcyr | Electrical Inspections | 20 | 1/6/08 4:47 AM |
| End of the light bulb as we know it!! | mcyr | General Inspection Discussion | 3 | 12/19/07 4:42 PM |
| Light Bulbs- All Ya Wanna Know | pabernathy | Electrical Inspections | 9 | 4/18/07 8:22 PM |
| How many forum members to change a light bulb? | kshepard | Miscellaneous Discussion for Inspectors | 9 | 8/2/06 10:56 AM |
