I put in the report to doublecheck what the temperature ratings were on the sprinkler head.
Could the amount of radiant heat that emits from the water heater flue pipe and possible spillage at start up cause an issue with this sprinkler head? "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
| Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Considering you can touch the outer wall of the double wall flue with your hand, I wouldn't think so. You've got codes that require "distance to combustibles", and it looks like that's okay. If it got hot enough to set off the sprinkler, I would imagine it would be a good thing for the sprinkler to be going off anyway. But I don't know what the "codes" say about proximity. But, that's just my logical observation, and not based on any codes or requirements I've read. Others with specific sprinkler experience may chime in with more experienced thoughts.
The operating temperature of the frangible bulb is around 155 degrees for the red bulb. A B-vent should never allow that much heat to escape.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 7/22/10 at 12:05 PM.. |
Only if the appliance is operating at normal temps.
If the appliance isn't operating properly, and the B-vent is emitting temperatures above 155 degrees, the appliance is probably on fire. In which case, we would hope the sprinkler head is functioning properly. . .
That first year was one of great learning. |
So much for efficiency
These ones are actually more appropriate for residential utility closets. The green bulb is rated at 200 degrees F.
| Opinion: Smoke Alarm Location | cevans | Interior Inspections | 10 | 6/16/09 6:31 PM |
| Receptacle location, Code In "FLORIDA" | jacaron | Electrical Inspections | 8 | 11/8/08 5:23 PM |
| Wisconsin Structure for Home Inspectors - Location Change | dnice | General Inspection Discussion | 0 | 1/10/07 4:21 PM |
| Well pressure tank location | dtaylor | Ancillary Inspection Services & Additional Topics | 5 | 8/31/06 6:07 AM |
| A/C location of expansion device vs line temps. | bking | Inspecting HVAC Systems | 9 | 5/29/06 4:16 PM |
