NEWS from CPSC Office of Information and Public AffairsWashington, DC 20207U.S. Consumer Product Safety Commission FOR IMMEDIATE RELEASE December 22, 2009 Release # 10-087 Firm’s Recall Hotline: (88 CPSC Recall Hotline: (800) 638-2772 CPSC Media Contact: (301) 504-7908 Temperature and Pressure Relief Valves for Large Water Heaters Recalled by Watts Regulator Due to Rupture and Burn Hazards WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission, in cooperation with the firm named below, today announced a voluntary recall of the following consumer product. Consumers should stop using recalled products immediately unless otherwise instructed. Name of Product: One-inch 140X-9 Temperature and Pressure Relief Valves Units: About 900 Manufacturer: Watts Regulator Co., of North Andover, Mass. Hazard: The relief valve can fail to reduce pressure and avert failure or rupture of the water heater tank and associated valves, posing rupture and burn hazard to consumers. Incidents/Injuries: None reported. Description: This recall involves the one-inch 140X-9 Temperature and Pressure Relief valves, which are typically used in large water heaters for commercial buildings or possibly for large homes. The valves bear item codes 0259844 (75 psi/210°F); 0259924 (100 psi/210°F); 0259708 (150 psi/210°F); 0259925 (125 psi/210°F); and 0259930 (150 psi/210°F). The affected date codes are 0641R through 0930R. The date code is printed after the model number “M15” on a green metal tag fastened to the pressure relief valve. Sold by: Authorized distributors nationwide from October 2006 through July 2009 for between $250 and $280. The valves were typically sold as replacement parts for large water heaters used in commercial locations or possibly large homes. Manufactured in: United States Remedy: Consumers should immediately contact Watts Regulator to schedule a free repair. Consumer Contact: For more information, contact Watts Regulator toll-free at (88 ![]() ![]() --- CPSC is still interested in receiving incident or injury reports that are either directly related to this product recall or involve a different hazard with the same product. Please tell us about it by visiting https://www.cpsc.gov/cgibin/incident.aspxThe U.S. Consumer Product Safety Commission is charged with protecting the public from unreasonable risks of serious injury or death from thousands of types of consumer products under the agency's jurisdiction. The CPSC is committed to protecting consumers and families from products that pose a fire, electrical, chemical, or mechanical hazard. The CPSC's work to ensure the safety of consumer products - such as toys, cribs, power tools, cigarette lighters, and household chemicals - contributed significantly to the decline in the rate of deaths and injuries associated with consumer products over the past 30 years. To report a dangerous product or a product-related injury, call CPSC's Hotline at (800) 638-2772 or CPSC's teletypewriter at (301) 595-7054. To join a CPSC e-mail subscription list, please go to https://www.cpsc.gov/cpsclist.aspx. Consumers can obtain recall and general safety information by logging on to CPSC's Web site at www.cpsc.gov. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
| Find an InterNACHI certified Indiana Home Inspector (and anywhere else in North America) |
Good info, but I never see 1 inch valves in my market.
Only 900 units nation wide. I wonder how many will actually make it back??? Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
Thanks for the info. These were 1 inch valves not the type you provided.
| CPSC Recall | hspeakman | Inspecting HVAC Systems | 2 | 9/9/09 9:34 PM |
| CPSC recall | badair | Plumbing Inspections | 2 | 1/16/09 3:29 PM |
| CPSC recall | badair | Inspecting HVAC Systems | 0 | 1/15/09 6:53 PM |
| Shut off valves required? | jcahill | Plumbing Inspections | 11 | 9/2/08 1:07 AM |
| Recall Notice - CPSC Notice | pabernathy | Electrical Inspections | 1 | 1/25/07 7:34 PM |
