I understand that CPVC pipe is acceptable for interior plumbing but PVC pipe is not because PVC pipe is not as strong as CVPC.
What about the fittings? I know they make CPVC fittings and have no idea why somebody didn't use them here. Heres the pic, any comments, please? http://nachi.org/forum/attachment.php? Last edited by waksell; 5/6/07 at 3:06 PM.. |
From my understanding the two are not compatible. They will not glue to each other properly. The connections will leek.
At one time I thought that one was OK for cold water only & the other was OK for both cold & hot water lines. I have never heard that PVC was not acceptable for water supply. I would never use PVC or CPVC outdoors myself though. CPVC & PVC are like copper & Galvanized pipe, they should not be connected directly to each other. If anything is not correct please let me know & point out why I am not correct. Thanks. Jason Sieg, CMI Davison, MI NACHI05091399 Knowing the current condition, to make a wise decision.
President, Great Lakes-East Chapter Join NACHI Great Lakes - East Chapter http://mi.nachi.org/greatlakes-east/about.html ssieg@gfn.org |
PVC is not allowed for interior distribution. That is to say, no PVC piping, and no PVC fittings.
Regardless of their compatibility, PVC is not allowed. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
PVC is used all the time for outside (i.e. sprinkler systems.)
PVC is allowed for exterior use as service or cold water distribution - whether irrigation or potable supply.
PVC (piping and/or fittings) is not allowed for use inside the residence. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I would just like to understand the reasoning behind this. Can a code be pointed out... I do see the chart in the CODE CHECK, I would like to understand the reasons. CODE CHECK Prohibited Joints --No glued joints between different types of plastic. IRC[2904.16.2] UPC{316.1.6} --No female threaded PVC fittings. IRC[2904.16.2] UPC{606.2.2} Jason Sieg, CMI Davison, MI NACHI05091399 Knowing the current condition, to make a wise decision.
CPC (UPC) 604.1 Water distribution pipe, building supply water pipe and fittings shall be of brass, copper, cast iron, galvanized malleable iron, galvanized wrought iron, galvanized steel, or other approved materials. Asbestos-cement, CPVC, PE, PVC, or PEX water pipe manufactured to recognized standards may be used for cold water distribution systems outside a building. CPVC, PEX water pipe, tubing, and fittings, manufactured to recognized standards may be used for hot and cold water distribution systems within a building. All materials used in the water supply system, except valves and similar devices shall be of a like material, except where otherwise approved by the Administrative Authority. For the IRC, refer to Table T2904.5 IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Thanks Jeff, That was the only thing I could think of myself.
Does anyone else have any other idea why PVC can not be used indoor for potable, cold water. I know it can not be used for hot water. Also does anyone know if PVC was ever OK for potable water. We have this kind of discussions all the time about Electrical... why not about plumbing! Jason Sieg, CMI Davison, MI NACHI05091399 Knowing the current condition, to make a wise decision.
Code inspectors can not quickly determine if PVC is present for the hot lines so they just disallow it completely for all of the indoor lines.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
This might help some.
PRESSURE APPLICATIONS Plastic pressure piping is used for many industrial processes, in heating and cooling systems, fire protection installations, gas distribution, and for water supply and distribution. Potable water applications include cold water services from wells or water mains up to the building as well as hot and cold water distribution piping within buildings. ABS, PE and PVC materials are all available with 73 F stress rating for use in pressure piping. PE piping is used extensively for cold water service lines and water distribution systems outside the building. Its low temperature flexibility make it especially suited for use in applications where temperature of 35 F and lower will occur. The maximum temperature at which PE has an HDS rating is 140 F. MATERIALS WITH HDS RATINGS FOR HIGHER TEMPERATURES Chlorinated Poly (Vinyl Chloride) (CPVC), and cross-linked polyethylene (PEX) materials are available that are rated for long term service at 180 F as well as for cold water applications. Hot and cold water distribution system piping made from these materials has a working pressure rating of 100 psi at 180 F. These systems are tested at 150 psi at 210 F for at least 48 hours to assure integrity at those condition, which may develop in the event the water heater controls malfunction. Thus, such materials are suitable for hot water distribution where water heaters are installed with relief valves set at 150 psi, 210 F. All plumbing codes require the use of piping having the 100 psi @ 180 F rating for both the hot and the cold water portions of the water distribution system. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
We know it is sanitary because it is allowed for main service pipe. Ive been using SCH 40 PVC for years as air piping in cabinet shops and we often run 140 psi., so it can handle the pressure. |
jlybolt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Marcel is right. It has to do with temperature ratings.
Now it all comes together. This is good information.
Codes, in my opinion, mean anything if you don't understand why they were created. So, the fast & simple answer to why PVC pipe is not acceptable for interior water distribution is: PVC pipe is not rated for Hot Water & a code inspector is unable to quickly or easily distinguish if a distribution line is a hot or cold water line. The additional information about how plumbing is tested is great to know about, Thanks. Jason Sieg, CMI Davison, MI NACHI05091399 Knowing the current condition, to make a wise decision.
This bothers me.
I understand and agree with everything said so far. My problem is, we are not supposed to be doing code inspections. We are supposed to be inspecting to alert clients of possible safety hazards and property damage. How can we defect PVC pipe on a cold water line when there is nothing wrong with it except that it is a code violation? Maybe its just me, but I'm going to have a hard time trying to explain to a client why I defected the PVC. |
In the example that was given here PVC fittings were used on CPVC pipe. They are not compatable and should never be glued together. The O.D. of the one pipe is different then the I.D. of the other pipe. It will leak eventually. It's just a mater of time. Jason Sieg, CMI Davison, MI NACHI05091399 Knowing the current condition, to make a wise decision.
| Insulation on pipes | jmichalski | Plumbing Inspections | 9 | 5/18/07 7:16 PM |
| Water heater supply piping | cpetty | Plumbing Inspections | 6 | 3/31/07 4:44 PM |
| TPR Drain up and out of crawl space??? | tsiegert | Plumbing Inspections | 25 | 3/12/06 4:38 PM |
