Old 4/20/10, 5:32 PM
Kenny Rigler Kenny Rigler is offline
Default CPVC on Condensate Pump Drain
Hey Folks-
Hopefully I haven't used up my question quota for the week...but I wanted to ask on this one as well. Usually on condensate pumps I always see the flexible plastic tubing. On this one they did connect flexible tubing directly but then quickly changed over to CPVC, even on the uphill climb. Is that something to be concerned about?
Thanks.
Kenny
Rigler Home Inspections
Hays, KS 67601
785-656-0272
Need a home inspection in South Carolina? Check out InterNACHI's listing of South Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/20/10, 7:37 PM
Joe Funderburk, CMI's Avatar
Default Re: CPVC on Condensate Pump Drain
I don't see why it would be a problem. I always include a note telling them a mechanical pump was in use, that they fail, and should be frequently monitored.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 4/20/10, 8:47 PM
I didn't get the manufacturer on this one but looked up the installation instructions on a standard condensate pump and it said:
"The outlet piping should be flexible tubing secured with a hose
clamp (not provided) or pipe (3/8 inch I.D. maximum to prevent
excessive flow back to unit)."
I would interpret the "or pipe" to include CPVC but wanted to double-check with you all. Thanks.
Kenny
Hays, KS 67601
785-656-0272
Old 4/20/10, 8:51 PM
Was it larger than 3/8"?
Larry Kage, CMI
231 929 3525
Old 4/20/10, 10:20 PM
Yep, I just found a pic that confirms it's 1/2" pipe. Is that enough information to call it out? Or do I need to determine the exact manufacturer of the pump and check it's installation instructions to see what it requires?
Kenny
Hays, KS 67601
785-656-0272
Old 4/20/10, 10:26 PM
Wayne B. Wilson's Avatar
IMO it will not work, I would Write it up .No back check so it will run back
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 4/20/10, 10:38 PM
Bob Elliott's Avatar
I would write up that bad chimney too.
Old 4/20/10, 10:39 PM
If the unit has been there for a while and you saw no evidence of overflow, I'd just learn from this thread and move on. I doubt you'll be sued over it. We'll all know better next time we see it.
Theodore Roosevelt
Joe Funderburk, CMI
Old 4/20/10, 10:41 PM
Where was it located?
Theodore Roosevelt
Joe Funderburk, CMI
Old 4/20/10, 10:42 PM
Hehe
Since no one asked yet ,check out the hood.
Old 4/20/10, 11:11 PM
Hey Joe-
Furnace room is in the middle of the basement. Interestingly, they shot that thing up and then probably over a good 15' and then brought it down into the washer drain. Problem though..the 1/2" drain line takes up enough space in the washer drain that the washer hose doesn't fully fit in there.
Hays, KS 67601
785-656-0272
Old 4/20/10, 11:16 PM
So if you don't call it out and if the unit fails in the basement, what type of damage would result?
Theodore Roosevelt
Joe Funderburk, CMI
Old 4/20/10, 11:17 PM
Bob - what the hey are you talking about? I didn't give you any pictures of the hood or chimney (but they were both bad!)
cpvc-condensate-pump-drain-img_6842.jpg   cpvc-condensate-pump-drain-img_6844.jpg
Hays, KS 67601
785-656-0272
Old 4/20/10, 11:18 PM
Looks like it fit to me. Not much room to spare, but it fit.
Theodore Roosevelt
Joe Funderburk, CMI
Old 4/20/10, 11:24 PM
I didn't see any open floor drains in the basement. Half the basement has recently been re-done...other half is crawlspace. I just sent out the report earlier today (client accesses online). I think I'll update the report and email the client on the change. I feel it's worth noting...even if I likely won't get sued over it. I'd rather not take the chance .
Hays, KS 67601
785-656-0272
Sump pump requirements Matthew Klein Plumbing Inspections 0 12/30/09 3:53 PM
Condensate pump in the attic jfunderburk Inspecting HVAC Systems 7 9/15/08 11:26 AM
Condensate pump instead of drain piping lfoster Inspecting HVAC Systems 7 6/22/08 3:16 PM
condensate drain lprinzi Inspecting HVAC Systems 3 8/11/06 5:57 PM
