Old 12/28/07, 11:45 AM
mnahrgang's Avatar
Default Pex & Tpr
I inspected some new construction the other day where they had a PEX line running from the TPR on the water heater.
I'm not real familiar with PEX and was wondering how flexible it gets when hot water is running through it. Is this discharge going to turn into a broken fire-hose during a major discharge, or will it remain mostly rigid?
Mark Nahrgang
www.HeyMark.info
Old 12/28/07, 11:53 AM
James H. Bushart's Avatar
Default Re: Pex & Tpr
I'd write it up, siting that its use is restricted to cold water supply, only.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 12/28/07, 11:58 AM
mnahrgang's Avatar
Are you sure about that? They had both Red and Blue PEX (hot and cold) throughout the house. I've seen this before, just not on a TPR.
Mark Nahrgang
www.HeyMark.info
Old 12/28/07, 12:08 PM
Depends on who you talk to.
The vendors say it can be used for both systems, but several plumbing resources (i.e. "Plumber's Pocket Manual, 10th Edition, Miller, Miller and Almond, page 183) advise using it only with cold water systems.
In your case though, since it is used for hot water throughout the house, why not the TPR - unless the copper pipe serves to provide a rigid channel to force the scalding discharge to the ground where the PEX could have it shooting in all directions?
James H. Bushart
314-803-2167
Old 12/28/07, 12:16 PM
bzimbelman bzimbelman is offline
Mark,
This was discussed not to long ago, and the answer is some locals allow it on the TPR and others do not.
No one gave an instance where it has failed on a TPR, so if/when I see it my write up is going to basically say that various areas allow PEX, others do not but I know of no known instances where it has failed.
Hope that helps!
-- bz
Brian Zimbelman
Circle Z Inspection Services
http://www.circlezinspections.com
575-535-4481 (wk)
575-313-1281 (cell)
mnahrgang's Avatar
I called the folks at pexconnection.com (http://www.pexconnection.com), and asked the guy who answered the phone if it was a proper usage of the material. His response was "absolutely". He said the material is pretty rigid, and there should be no problems with a discharge.
I found their catalog to also be fairly informative as well (pexconnection catalog) and helpful in helping educate me a little more.
Thank you all for your comments. That's very helpful.
Mark Nahrgang
www.HeyMark.info
Old 12/28/07, 12:21 PM
cgoyette cgoyette is offline
Please Note: cgoyette is a non-member guest and is in no way affiliated with InterNACHI or its members.
Mark,
I would right it up as not a appropriate application. Think about 150 PSI and 210 degrees....you get a fire hose flying around.
Curt
Old 12/28/07, 12:34 PM
mnahrgang's Avatar
Originally Posted by cgoyette
Mark,
Curt
Hey Curt,
I clearly see your point, and agree with with what you are saying. What would you say in the report?
Because I could see this as becoming a huge "p...ing" match between me an the builder. Especially if the manufacturers say it's appropriate, and the AHJ doesn't have a problem with it.
Mark
Mark Nahrgang
www.HeyMark.info
Old 12/28/07, 1:01 PM
Michael Larson's Avatar
Mark,
Curt
Ah, but the pressure is not 150 PSI on a open unterminated line.
PEX is just fine for this application though I would recommend it be secured to prevent whipping in the event of TPR discharge.
My opinion. Take it or leave it.
Old 12/28/07, 1:05 PM
Mike,
Agree but how do you PROPERLY secure it? no matter what if the TPRV has to be used it will cause a nightmare even if for just a second as a hot water waving wildcat! Way easier to make it copper or gold guard. IMHO.
Curt
Old 12/28/07, 1:10 PM
mnahrgang's Avatar
For the record everyone... This PEX wasn't particularly flexible. It's pretty firm. I could move it a few inches, but that's about all. It was just slightly more flexible can a copper tube. My concern was how it would react after it got hot and under pressure.
I wrote up another TPR valve that same day that had a rubber hose connected to it. That one was totally flexible.
I just don't know with this one. That's why I posted, and it's also why I'm so appreciative of this ongoing discussion.
Mark Nahrgang
www.HeyMark.info
Old 12/28/07, 1:20 PM
The best course of action whuld be to check with your local AHJ as I know at least some states do not permit the use of PEX for the TPR discharge piping.
If you want a definitive answer for what is permitted in the areas you inspect, contact your AHJs.
Old 12/28/07, 1:33 PM
cbuell's Avatar
cbuell cbuell is offline
Please Note: cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have never heard of pex becoming more flexible with hot water in it. If it was, the spacing of horizontal supports would be different. I seriously doubt it is a problem on the TPRV----some jurisdictions require that it be strapped to the side of the tank at the bottom, which I think is a good idea any way. It just looks kinda funky because it usually curls a little
Old 12/28/07, 3:01 PM
dgagneur's Avatar
dgagneur dgagneur is offline
Please Note: dgagneur is a non-member guest and is in no way affiliated with InterNACHI or its members.
I am not an expert on PEX but have worked with it in my last two homes. Even when hot water is run through it, it stays fairly rigid. I'd have a hard time believing it would actually whip around upon discharge of the TPR.
My opinion, if the local AHJ allows it, then it's not wrong so why write it up???
Dave
Old 12/28/07, 4:25 PM
Randy L. Thomas Randy L. Thomas is offline
Please Note: Randy L. Thomas is a non-member guest and is in no way affiliated with InterNACHI or its members.
As an inspector, PEX is no problem but we require it to be secured at the bottom. Usually installers will use a hose clamp with 2 very short screws into the metal jacket. Code doesn't spell out the method or materials of the discharge line, just per mfr's recommendations.
Uponor bought out Wirsbo a couple years ao and they are the industry leader in PEX >>> http://www.uponor-usa.com/.
