Old 10/10/12, 3:28 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
Default Pex clamping
Does anyone have any wording about using "alternative" clamps on PEX fittings? Such as a hose clamp vs the normal binding rings?
Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/10/12, 3:40 PM
jfunderburk's Avatar
jfunderburk jfunderburk is offline
Please Note: jfunderburk is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Pex clamping
Say something simple like "The fitting at the XXX is not approved for for use and should be replaced by a licensed plumbing contractor."
2009 IRC P2608.3 Plastic pipe, fittings and components. All plastic
pipe, fittings and components shall be third-party certified as
conforming to NSF 14.
P2608.4 Third-party testing and certification. All plumbing
products and materials shall comply with the referenced standards,
specifications and performance criteria of this code and
shall be identified in accordance with Section P2608.1. Where
required by Table P2608.4, plumbing products and materials
shall either be tested by an approved third-party testing agency
or certified by an approved third-party certification agency.
Old 10/10/12, 3:47 PM
Mike Auger's Avatar
Mike Auger Mike Auger is online now
I usually go with:
"clamping device used here is not type reccomended for propert installation by manufacturer. It is also not in line with current building standards. reccomend a licensed qualified plumber repair properly."
or something like that.
Mike Auger
R.I Home Inspector
NACHI Certified Home Inspector
IAC2 Certified
Rhode Island Home Inspection Service
RI # 32856
(401) 578-4878
A U.S.A.F. Veteran Owned Corporation
Old 10/10/12, 4:23 PM
Timothy J. Smith, CMI Timothy J. Smith, CMI is offline
"Non standard materials used for clamping purposes. Repairs and further evaluation required by a licensed plumber"
TJ Smith
Serving Brockville, Ontario and Surrounding Area
TJ@AllOutHomeInspection.com
http://www.allouthomeinspection.com
"Inspecting your Future"
Old 10/10/12, 10:26 PM
Duane D. Nelson Duane D. Nelson is offline
I use "improvised and unconventional" alot
Old 10/11/12, 9:20 AM
PEX fittings should be attached to the PEX water lines with PEX crimp rings. The rings will say PEX on them. Anything else, refer.
Certified Master Inspector, KS #0110-0094
Termite #16601 KS Radon #KS-MS-0027
BBB A+ Accredited Business
Serving the Greater Kansas City Metro Area
Eastern Kansas/Western Missouri
http://www.metrospeckc.com
"If opportunity doesn't knock, build a door"--Milton Berle
Old 10/14/12, 7:48 PM
Mark Karson Mark Karson is offline
Please Note: Mark Karson is a non-member guest and is in no way affiliated with InterNACHI or its members.
The copper fittings for PEX are the best, but you can use hose clamps if you heat the PEX with a heat gun or hair dryer to soften the end and then tighten the hose clamp. I have in floor heat in my house and have both types of clamps in use and neither one leaks. So if you can't get the crimper in your space allowed you could try the hose clamp method.
Short circuit failures with 12/3 NM-B cable and NM clamp connectors pabernathy Electrical Inspections 10 4/17/11 1:43 PM
soldered double tap phinsperger Electrical Inspections 38 5/24/06 6:47 PM
