Old 12/1/11, 2:08 PM
Ed Mitchell Ed Mitchell is offline
Send a message via ICQ to emitchell
Default Pex connection on a Water Heater
I saw this installation today on a brand new water heater. This is a new construction home. It is a high efficient gas water heater. According to the IRC you must have 18 inch clearance from the top of the water heater to your Pex connection. But I am thinking since this is a high efficiency with an induced fan, that it not necessary. What does everyone else think?
Ed Mitchell
Amerispec Home Inspection
NJ Lic. #24G100106600
Infraspection Level 1 Certified 8456
(856)649-5946
(973)936-3420
www.amerispecnj.net
Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/1/11, 2:10 PM
Joe Funderburk, CMI's Avatar
Default Re: Pex connection on a Water Heater
Where is that code?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 12/1/11, 2:43 PM
Marcel Gratton's Avatar
May have to do with piping manufacturer installation guidelines.
http://www.ppfahome.org/pdf/PEX%20In...20Handbook.pdf
On The Level Inspection
Gatineau, Québec
Old 12/1/11, 2:45 PM
Christopher Currins's Avatar
Being that's a power vent check with the manufacturer instructions.
Christopher Currins
Certified, Licensed
Old 12/1/11, 3:11 PM
Here is the code:
604.11.2 Water Heater Connections. PEX shall not be installed within the first 18 inches
(457 mm) of piping connected to a water heater.
I also contacted bradford white, the service tech I spoke to, didn't think it would be a problem. Due to the closed combustion.
Ed Mitchell
(856)649-5946
(973)936-3420
www.amerispecnj.net
Old 12/1/11, 3:13 PM
Jeffrey R. Pope's Avatar
The "code" is clear, and makes no mention of the type of heater.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/1/11, 3:15 PM
Here is the code:
That's the UPC Code, not IRC.
Christopher Currins
Certified, Licensed
Old 12/1/11, 5:05 PM
Scott May's Avatar
Scott May Scott May is offline
Send a message via Skype™ to smay
Further to your question Ed was there a dielectic fitting there because although the pic is quite blurry it looks as though the fittings are galv. coming from the Hw tank
Try not to become a man of success but rather to become a man of value!
WWW.eyespy-homeinspections.ca
Serving: Collingwood, Creemore, Dundalk, Durham, Flesherton, Hanover, Kincardine, Mansfield, Markdale, Meaford, Owen Sound, Port Elgin, Sauble Beach, Shelburne, Southampton, Stayner, Thornbury, Wasaga Beach and Wiarton.
Old 12/1/11, 7:31 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
Why would you need a dielectric fitting between plastic and galvanized? My question is regarding what looks like a valve at the hot water T. What was that for?
Stephen Stanczyk
Old 12/1/11, 8:25 PM
The valve that is coming off the hot water side is require, per the manufacture. There are pressure limits on Pex that the manufacture specify.
PEX Operating Pressure &
Temperature Limits
Water
160 psi@73ºF (1.10MPa@23ºF)
100 psi@180ºF (0.69MPa@82ºF)
Chlorinated Water
80psi@140ºF (0.55MPa@60ºF)
Recirculating Loops
There was no dielectic fitting present. There should be no need for one.
Ed Mitchell
(856)649-5946
(973)936-3420
www.amerispecnj.net
Old 12/1/11, 10:53 PM
Here is the code:
604.11.2 Water Heater Connections. PEX shall not be installed within the first 18 inches (457 mm) of piping connected to a water heater.
That is not the IRC. The UPC is not adopted in this part of the country.
Theodore Roosevelt
Joe Funderburk, CMI
Old 12/1/11, 11:41 PM
Temperature Limits
Water
Chlorinated Water
So what type of valve is it since temperature sets the pressure? Would it not need to be installed within the water heater to get a proper temperature reading?
Since it has lesser temp and pressure requirements, shouldn't it be installed where the TPR valve is located? In all the new construction that is using PEX, I have never seen a 2nd valve like this, but then I also have not looked at the specs for the TPR valves.
Stephen Stanczyk
Old 12/2/11, 6:52 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
What is the allowed temperature on the TPR? This is why it cannot be PEX because PEX is rated for lower temperatures and sometimes pressure. Howerver the AHJ may have allowed it knowing the chances of pressure are limited due to two PRVs installed.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 12/2/11, 1:35 PM
Just got off the phone with the Uponor (Wirsbo brand PEX) technical support / code supervisor and explained the application below.
1. A 2nd valve is NOT required.
2. The normal TPR valve is adequate for all residential potable water plumbing systems.
3. PEX has an extreme high limit use of 210 degrees at 160 psi for 24 hours in case the TPR valve fails.
4. The 18" rule is in effect for all types of water heaters.
Hope this helps.
Stephen Stanczyk
Old 12/2/11, 2:09 PM
Per the IRC, PEX is acceptable for the TPR discharge piping.
Theodore Roosevelt
Joe Funderburk, CMI
Solar water heating + electric water heater Todd M. Soper Plumbing Inspections 20 5/30/07 6:31 AM
Water Heater Dip Tube Failure jacaron Plumbing Inspections 2 2/24/07 11:28 PM
Draining a mobile home hot water heater. Steve Evets Plumbing Inspections 11 2/20/07 11:28 PM
