Old 12/7/08, 7:23 PM
jlerch jlerch is offline
Default Pex to Hose Bib
Does there need to be a section of copper before PEX connects to a hose bib? Is there a standard? I saw it recently and could use a little help.
Thanks.
Knowledge You Can Trust... Service You Deserve
Old 12/7/08, 8:03 PM
Marc D. Shunk's Avatar
Banned
Default Re: Pex to Hose Bib
That's not exactly a hose bib. That's a ball valve.
Old 12/7/08, 8:09 PM
Mark, I think John knows that, I believe the hose bibb is a little lower in the picture, where else would you have a water line go near a garage door.? ha. ha.
Marcel
Old 12/7/08, 8:11 PM
David P. Valley's Avatar
Where's the spigot?
And I always recommend winterizing those lines in an unconditioned garage.
Old 12/7/08, 8:17 PM
Originally Posted by dvalley View Post
Where's the spigot?
Dave, right there at the bottom of the photo, don't you see it?
Heated garage too! In the back corner.
John, I think you need to expand on the extent of your photo and what you are looking at so we can stop guesstimating.
Marcel
Old 12/7/08, 8:21 PM
Marcel
I must be going blind....
Old 12/7/08, 8:23 PM
Old 12/7/08, 8:29 PM
My bad...
I need to retrieve CRM - correct picture to follow
Old 12/7/08, 9:53 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
I have seen PEX attached to FROST PROOF hose bib valves.
Old 12/8/08, 9:28 AM
Brian E. Kelly's Avatar
Thanks.
I would like to see the hose bib John. I would think the answer is it would be OK if the hose bib was well supported so no stress was transfered to the piping.
I see PEX connected directly to angle stops in bathrooms all the time here.
Old 12/8/08, 9:41 AM
I'll be back later w/pic
Old 12/8/08, 10:25 AM
Isn't PEX supposed to be more forgiving under freezing temps? I don't get to see it at all since it's still not allowed around here. However, all the big box stores still supply it.
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 12/8/08, 10:46 AM
Jeff
PEX piping is freeze damage resistant and can expand and contract as water freezes and thaws within the tubing. No tubing material is freeze-break proof, however, and PEX should be installed using the same locally-prescribed insulation requirements to prevent freezing of any plumbing system.
I'm seeing it all the time here on New Construction in unconditioned spaces and we have absolute frezzing temperatures. Today was 11 degrees F. I haven't seen PEX freeze yet.
Old 12/8/08, 10:51 AM
Bruce A. King's Avatar
If the hose bibb is properly fastened to the wall you can have pex going to it.
If the pex passes through brick it must have a sleeve.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 12/8/08, 6:06 PM
And now the updated picture...
How many hose bibbs on a new home? jfunderburk Plumbing Inspections 14 6/5/08 11:24 PM
bonding main hose bib with pex Scott Schultz Electrical Inspections 5 6/21/07 11:39 PM
Hose from copper piping.. gbrasseur Plumbing Inspections 9 4/29/07 8:53 PM
Outlet under hose bib kblair1 Electrical Inspections 10 11/6/06 4:45 PM
Hose pipe distance from outlet lprinzi Plumbing Inspections 2 10/21/06 4:20 PM
