I inspected a home yesturday that the potable water lines were Pex Tubing almost translusent white. But all the fittings looked like the Old Grey Polybutylene Fittings. What type of fittings can be used?
Rick Kie |
To expand on this they are large grey compression type fittings
Rick Kie |
A picture would be helpful. Wirsbo brand PEX uses this type of connection ring instead of the metal compression rings. http://www.pexsupply.com/categories.asp?cID=54
Is this what you are talking about? Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Here is a picture of the pipe and the fittings
Rick Kie |
Anyone have an answer for me?
Rick Kie |
Hi Rick,
I tried to research this for you but can't find the deffinative answer, but heres my thoughts. All of the PEX manufacturers have very specific installation guides and adherance to those is part of the warranty, all that I have seen have used a metal "barbed" fitting and a special crimp tool to make the joint, I have never seen that fitting used with PEX and believe it to be wrong, but I'd need to know the pipe manufacturer to be 100% sure. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
The fittings look like Polypropylene to me. http://www.pexinfo.com/ http://www.lawyersandsettlements.com...-complaint.pdf Last edited by bkelly2; 2/13/09 at 11:00 AM.. |
That is a PB fitting but not one that was included in the settlement fund.
http://www.pbpipe.com/Eligibility/Ex...9/Default.aspx I don't think the exact dimensions are the same so that PB fitting should not be used with PEX or at least not considered a PEX plumbing component making it technically wrong. Here is a picture of a polypropylene fitting: http://www.grainger.com/Grainger/items/2ZRY4?img and another color: http://www.coleparmer.com/catalog/pr...sp?sku=3160330 B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Is it possible it could have been fittings as shown below.
I have seen some similar on jobs and they were Watts fittings. This is similar. http://www.ardipex.com/pex-fittings-compression.php Compression PEX Fitting (PF1) PEX Equal straight union SpecificationsDescriptionPF1-S1216×1216PF1-S1620×1620Both ends connected to PEX pipes of same size. E.g.: F1-S1620×1620 means both ends connected to PEX pipes 1620.PEX Male union SpecificationsDescriptionPF1-S1216×1/2One end connected to PEX pipes,the other to female threads.E.g.: F1-S1620×1/2 means one end connected to PEX pipes 1620,the other to 1/2 female threads.PEX Female union SpecificationsDescriptionPF1-S1216×1/2FPF1-S1620×1/2FOne end connected to PEX pipes,the other to male threads. E.g.: F1-S1620×1/2F means one end connected to PEX pipes 1620, the other to 1/2 male threads.PEX Equal elbow SpecificationsDescriptionPF1-L1216×1216PF1-L1620×1620Both ends connected to PEX pipes of same size. E.g.: F1-L1620×1620 means both ends connected to PEX pipes 1620.PEX Female elbow SpecificationsDescriptionPF1-L1216×1/2FPF1-L1620×1/2FOne end connected to PEX pipes,the other tomale threads. E.g.: F1-L1620×1/2 F means one end connected to PEX pipes 1620,the other to 1/2 male threads.PEX Wall-plated female elbow ![]() E.g.: F1-L1620×1/2 F(Z) means one end connected to PEX pipes 1620,the other to 1/2 male threads.PEX Equal tee ![]() E.g.:F1-T1620×1620×1620 means three ends connected to PEX pipes 1620.PEX Connector core for manifold Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
The Pipe look more like CPVC rather than PEX.
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
It is marked pex Dale. http://www.astm.org/Standards/F876.htm Perhaps Flair-It Fittings???? http://store.flairit.com/c-99-flair-it-male-tees.aspx http://store.flairit.com/c-89-flair-it-couplings.aspx Last edited by bkelly2; 2/13/09 at 1:30 PM.. |
Hey Guys thanks for the help. I sent your replys to the buyers Realtor to discuss with his client. I still dont have a definite answer but it has to be wrong I think i'll call the manufacturer of the pipe and E-mail them pics of the fittings.
Rick Kie |
| Pellet stove help | chellickson | General Inspection Discussion | 23 | 8/19/10 2:23 AM |
| Identify ABS defective pipe | mcyr | Plumbing Inspections | 6 | 1/29/09 7:39 PM |
| Vent pipe | dlee2 | Plumbing Inspections | 4 | 9/18/07 12:28 AM |
