Old 4/5/06, 10:08 AM
Ronald G. Chorey II's Avatar
Ronald G. Chorey II Ronald G. Chorey II is offline
Default PEX plumbing
Is it ok to use copper clamps on PEX pipe?
Old 4/5/06, 3:21 PM
phinsperger's Avatar
Default Re: PEX plumbing
There is no problem chemically from using a copper clamp. However, that type of clamp is sharp enough that abrasion from pipe movement against the clamp from thermal expansion and contraction may over time wear a weak spot in the pex. There are plastic clamps specifically made for pex pipes.
Old 4/5/06, 4:01 PM
Brian E. Kelly's Avatar
Pex Install Guidelines
Check out page 13 for clamps. Plastic clamps are recommended but approved metal clamps are ok.
Old 4/5/06, 8:45 PM
Thanks Paul and Brian
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 9:16 AM
No "H" clips? jbreazeale Structural Inspections 7 5/17/07 3:28 PM
Plumbing Code changes mcyr Plumbing Inspections 0 9/8/06 6:47 PM
A few useful posts - I forget from whom jmichalski Plumbing Inspections 12 3/30/06 10:06 PM
