I guess all plastics get brittle over time. Does anyone have any info on the life expectancy of PEX plumbing?
| Need a home inspection in California? Check out InterNACHI's listing of California certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
We know the factors that will result in fast deterioration (exposure to UV rays) and there are "slide rule" calculations that predict up to "200 years" by some estimates. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
http://www.phcnews.com/march_07/pex.php http://www.lowesforpros.com/pex-on-t...or-contractors http://www.2hsc.com/zurn/sections/pex.html |
James you are right on the ball!
Poly-B over 500,000 installations in households in Quebec and no recall! The question is weather it was well installed. Also if I may add that excessive quantities of chlorine was known to accelerate poly-B piping wear but it was also demonstrated that excessive chlorine had the same kind of effect on copper piping. Salut, Beauchemin Marc-Andre, BMAinspections.com, based out of Brossard Quebec-Canada. |
Marc-Andre,
If there were no problems with PB installations in Canada, why was there a class action suit filed and settled there? http://www.classaction.ca/actions/Pr...lene-Pipe.aspx Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
No. Marc-Andre brought up PB so I answered his response. But the original question was in regards to PEX. I don't know if he has them mixed up or not.
PEX will go the way of PB, I predict, sometime in the future.
Some fittings are already starting to fail. Installations are sloppy, I believe, with too many opportunities for shortcuts. I cant help but think of the scene in the movie Moonlighting, where Vincent Gardena explains plumbing to the homeowner that needs their bathroom repaired/renovated. "Copper... it costs more because its worth more." As to PEX, just say "To infinity and beyond !" No one can predict the future. As home inspectors, never speak about expected useful life, except for what the manufacturer gives you. Always say its the manufacturer's servicable life, if you quote at all. |
PEX piping has a great track record and is warrantied for as long as 25 years.
Some fittings. Not so much. Can you get anything approaching 25 year warranty on any other piping? You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
| Does anyone include InterNACHI's Life Expectancy Chart with every inspection report? | gromicko | Inspection Hardware, Software & Publications | 14 | 1/24/10 8:03 PM |
| Life expectancy of metal roof | rsole | Exterior Inspections | 8 | 3/26/09 10:01 PM |
| Life expectancy of well pumps? | rmaday | Plumbing Inspections | 15 | 10/13/08 8:44 PM |
| Normal Life Expectancy | jmckenna1 | Miscellaneous Discussion for Inspectors | 6 | 1/29/07 9:57 PM |
| A few useful posts - I forget from whom | jmichalski | Plumbing Inspections | 12 | 3/30/06 9:06 PM |
