Old 5/12/07, 3:11 PM
Russell E. Napper Russell E. Napper is offline
Default PEX on TRP
Has anyone seen PEX being used as the drain line for the TPR valve. Is it OK to use in this location. I know PEX is good stuff and inspect it alot in new construction, but this is the first time I have run across it on the TPR. Also, the plumber used 3/4 inch PEX on the hot water drain pan coming off an inch fitting. Thoughts please
Old 5/12/07, 3:19 PM
Jeffrey R. Pope's Avatar
Default Re: PEX on TRP
IRC 2803.6.2 says it's okay, UPC 608.5 says no.
The drain-pan piping does not matter. It can be whatever is available. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 5/12/07, 7:35 PM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
I see it fairly often in new construction and it's normally the Red on the TPV...
maybe they expect it might get Hot
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Old 5/14/07, 4:18 PM
Thanks for the help.
