Old 12/9/11, 6:13 PM
David P. OKeefe's Avatar
David P. OKeefe David P. OKeefe is offline
Default Pex to water heater
Is this pex too close to the exhaust flue on this water heater? I thought I just read somewhere whereit needs to be 18" away. Your thoughts. And there isn't enough vertical rise before the bend.
David
InterNACHI #08051301
NYS Lic. #16000038229
NYS DEC Cert # T4865884
518-505-8305
HouseAbout Home Inspections
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/9/11, 6:18 PM
James F. McKee's Avatar
Default Re: Pex to water heater
I've always heard the 18" also Dave...all Sharkbite fittings is prolly a handyman or home owner install...Plumber is not going to spend that kind of money for simple fittings...
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 12/9/11, 6:23 PM
Jeffrey R. Pope's Avatar
Yes. Too close to the vent (6 inches minimum), and too close to the water heater (18 inches minimum).
Didn't we already have this conversation?
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/9/11, 6:26 PM
Like I said I thought I seen it recently. thanks.
David
518-505-8305
Old 12/16/11, 3:17 PM
More info here
http://www.nachi.org/forum/f22/cross...-heater-66588/
Old 12/16/11, 8:39 PM
Roy Drangstveit's Avatar
Roy Drangstveit Roy Drangstveit is offline
A plumber told me the other day that the lines in & out of a water heater should be 3/4". This looks like 1/2".
Old 12/16/11, 9:00 PM
It may depend where you are. In my area they are always 1/2".
Old 1/4/12, 10:28 AM
Amalia Markous Amalia Markous is offline
Please Note: Amalia Markous is a non-member guest and is in no way affiliated with InterNACHI or its members.
My experiance has been that you should not use any sharkbites that close to a water heater. I've had them fail a couple of months after installation because of that. just get 2 brass female adapters, put them on the water heat and connect like normal.
Thanks and Regards.
Amalia Markous
________________________
Plumbing Services Fort Worth
Old 1/7/12, 12:26 AM
Juan C. Jimenez Juan C. Jimenez is online now
Isn't the flue piping suppose to slope upwards?
Tankless water heater issue sstanczyk Plumbing Inspections 18 12/2/10 6:15 PM
Solar water heating + electric water heater Todd M. Soper Plumbing Inspections 20 5/30/07 6:31 AM
Hot Water Heater djohnson6 Plumbing Inspections 12 12/28/06 9:18 PM
