Nathan W. Swilling is a non-member guest and is in no way affiliated with InterNACHI or its members.
Also posted in structural. Does this look kosher? The joist is about 2" thick and 7" wide. It looks like the cutout is more than 1/3 of the width of the beam. One joist is supported with some extra lumber, but it still doesn't look that great.
Over drilled and cracked too
So, what's the remedy? Would sandwiching it in OSB do the trick? How far on both sides?
How would that correct the oversized hole diameter.?
By hopefully strengthening that area. With an engineered joist, you can cut the hole as large as you want - I believe.
Maybe it needs to be sandwiched with an LVL? |
It's not acceptable the way it is and needs reinforcement with a product like THIS
Here is a animation Choose the hole reinforcer Photo Gallery http://gallery.metwood.com/.thumbnai...%2F.%2F001.jpg 001 http://gallery.metwood.com/.thumbnai...%2F.%2F002.jpg 002 http://gallery.metwood.com/.thumbnai...%2F.%2F003.jpg 003 You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell Last edited by mlarson; 6/24/08 at 1:16 PM.. |
Mike I wonder what was done before this newfangled invention.
Sister or replace and move the pipe,correct? |
Deeper floor structure to accommodate notching or holes is another. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Mike ,I meant after the fact.
Ok...............
Mike,
Additional Floor Joist spaced closer would just mean that the local plumber would have to cut more holes. In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
| Cutout of joist for toilet drain | Nathan W. Swilling | Structural Inspections | 33 | 6/26/08 1:48 AM |
| Inspector in hot water after approving unit without drain | rcooke | Canadian Inspectors | 7 | 2/20/08 3:59 PM |
| Child eviscerated by pool drain | mthomas2 | Ancillary Inspection Services & Additional Topics | 26 | 7/16/07 4:27 PM |
| Air leak from floor drain | yolhovsky | Plumbing Inspections | 5 | 2/24/07 6:43 AM |
| French drain tied into main drain | rwashington | Plumbing Inspections | 6 | 2/16/07 11:04 PM |
