Old 1/5/12, 1:13 PM
Roger Shafer, CPI Roger Shafer, CPI is offline
Default What dates where these types of pipe used?
Can you verify any of these dates?
Plumbing
Galvanized water pipes 1930 -19__
Copper 19__ - Present
Polyethylene, Pex 1985 -Present
Polybutylene, PB, grey piping 1970 -19__
Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/5/12, 3:55 PM
grusk grusk is offline
Please Note: grusk is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: What dates where these types of pipe used?
During the early 1900s, heavy-walled copper joined with threaded fittings was in use, but limited to public buildings because of its high cost. However, during the 1930s light-gauge Copper tube and fittings were developed which made copper economically feasible and increased its popularity. Polyvinyl Chloride(PVC) was produced experimentally in the 19th century but did not become practical to manufacture until 1926, when Waldo Semon of BF Goodrich Co. developed a method to plasticize PVC, making it easier to process. PVC pipe began to be manufactured in the 1940s and was in wide use during the DWV reconstruction of Germany and Japan following WWII. In the 1950s, plastics manufacturers in Western Europe and Japan began producing acrylonitrile butadiene styrene(ABS) pipe. The methods for producing cross-linked polyethylene (PEX) was also developed in the 1950s.
PVC/CPVC - rigid plastic pipes similar to PVC drain pipes but with thicker walls to deal with municipal water pressure, introduced around 1970. PVC should be used for cold water only, or venting. CPVC can be used for hot and cold potable water supply. Connections are made with primers and solvent cements as required by code.
Polybutylene plumbing was used in several million homes built in the United States from 1970 to the mid-1990s
Old 1/5/12, 4:59 PM
Joe Funderburk, CMI's Avatar
Roger, what is a "CPI"?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 1/5/12, 5:21 PM
Roger Shafer
Certified Professional Inspector
Buyers Protection Group
Old 1/5/12, 7:09 PM
Christopher Currins's Avatar
http://www.nachi.org/forum/f13/inter...pi-logo-67794/
Christopher Currins
Certified, Licensed
Old 1/5/12, 7:15 PM
http://en.wikipedia.org/wiki/Domestic_water_system
Pipe materials
The earliest known evidence of drain tile being used for plumbing was found in Mesopotamia and is estimated to have been made around 3000 BC. The tiles were made from clay mixed with short lengths of straw. Both brass and copper pipes have been found in Egypt believed to have been made close to 2500 BC. The Romans made extensive use of lead pipe by joining sheets of lead into piping to carry their water supply and waste. During the Dark Ages following the fall of the Roman Empire, plumbing development virtually ceased for centuries except for isolated cases of plumbing installed in palaces and castles. In the 13th century, blacksmiths formed sheets of iron and lap welded the seam to create iron pipe. Though it is unclear as to when galvanized iron pipe was first used, a French chemist named Melouin is credited with developing the process in 1742. The earliest known use for cast iron pipe is for the water supply to a fountain in Langensalza,Germany, built around 1560. In 1819 the first cast iron pipe constructed in the US, was manufactured in Weymouth, New Jersey. Before that time, cast iron pipe and fittings had to be imported from Europe. It was not until the 1960s that the hubless cast iron pipe was brought to the U.S. from Europe by way of Canada. During the early 1900s, heavy-walled copper joined with threaded fittings was in use, but limited to public buildings because of its high cost. However, during the 1930s light-gauge Copper tube and fittings were developed which made copper economically feasible and increased its popularity. Polyvinyl Chloride(PVC) was produced experimentally in the 19th century but did not become practical to manufacture until 1926, when Waldo Semon of BF Goodrich Co. developed a method to plasticize PVC, making it easier to process. PVC pipe began to be manufactured in the 1940s and was in wide use during the DWV reconstruction of Germany and Japan following WWII. In the 1950s, plastics manufacturers in Western Europe and Japan began producing acrylonitrile butadiene styrene (ABS) pipe. The methods for producing cross-linked polyethylene (PEX) was also developed in the 1950s. Plastic supply pipes have become increasingly common, with a variety of materials and fittings employed, however plastic water pipes do not keep water as clean as copper and brass piping does. Copper pipe plumbing is bacteriostatic. This means that bacteria can't grow in the copper pipes. Plumbing codes define which materials may be used, and all materials must be proven by ASTM, UL, and/or NFPA testing.
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 41 4/5/12 6:43 AM
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 1:23 AM
Is this allowed? belliott Plumbing Inspections 4 7/15/09 6:40 PM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 6:39 PM
