IRC P2803.6.1 states that the discharge pipe for a TPR valve "shall be piped full size separately to the floor, to the outside..., or to an indirect waste receptor located inside the building."
What is an indirect waste receptor? I've seen that term used elsewhere in the IRC. Please see the attached photo of a TPR valve drain connected in the crawl space to the water heater pan drain line, which discharges outside the house. It this acceptable? Is that an "indirect waste receptor"? Is the crawl space "inside the building"? Thanks.
Yes, It is acceptable (it's outside) and no that is not an Indirect Waste Receptor. An indirect liquid waste receptor is a plumbing fixture designed specifically to collect and dispose of liquid waste from other plumbing fixtures, plumbing equipment or appliances which are required to discharge to the drainage system through a physical air gap or listed air gap unit. The following are types of fixtures that commonly fall into the classification of acceptable indirect liquid waste receptors: Floor sinks, mop receptors, service sinks, laundry tubs and washing machine standpipe drains. Water closets of toilets in bathrooms are not acceptable as suitable indirect liquid waste receptors. Last edited by dvalley; 2/18/06 at 2:29 PM.. |
Thanks David. However, what is the meaning of the word "separately" in this phrase: ""shall be piped full size separately to the floor, to the outside..., or to an indirect waste receptor located inside the building."
Does that not imply that the piping can't join another drain? “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
A drain is a drain is a drain is a drain. Separately is implying that this TPR pipe needs to be on its own. But in this particular situation, these lines are not being used full time and are fine being connected together as they are. They are there for the sole purpose of ridding unwanted water to a convenient area if the water heater ever did fail. The installation you have here is absolutely fine. |
staylor is a non-member guest and is in no way affiliated with InterNACHI or its members.
David,
I would respectfully disagree with you on allowing the TPR valve to connect to another drain line. The TPR valve drain line should not be leaking/draining water unless there is a problem with the water heater or TPR valve. The reason for not mixing the TPR drain line with another drain line is to be able to identify water coming from the TPR drain line to alert the occupant of a potentially serious defect. If the lines are mixed, one may not be able to determine the source of the water draining in the drain lines. Consequently, TPR drain lines should not be mixed or connected with other drain lines and should terminate in a visible and accessible location. Steve Taylor Taylor Inspection Services, Inc. Amelia Island Florida 32034 www.taylorinspectionservices.com |
Steve,
This TPR valve drain line (in question) is connected to the WH pan drain line. Neither one of these lines should be leaking at any time and if they were, it would be pretty obvious to an average homeowner, hopefully. It is always great to have the discharge end of these two lines visible at all times, so that the average person can monitor these lines on a daily basis. So... all in all, having these two lines connected to each other is (in my mind) absolutely fine. Now if this TPR valve discharge pipe was connected to a full time waste line (like you think it is) then it would be an advisable issue. But (like I said), neither one of these lines should be leaking, period. If this discharge point was not viewable, and terminating in an area where it cannot be monitored (such as a crawl space), I would definitely advise my clients of the consequences. Last edited by dvalley; 2/18/06 at 6:41 PM.. |
| Waste line on OUTSIDE of house | gkeene | Plumbing Inspections | 6 | 9/18/07 10:15 PM |
| main waste pipe | bking | Plumbing Inspections | 1 | 5/17/06 10:14 PM |
