Old 10/3/08, 9:23 PM
sfalvey sfalvey is offline
Default On demand water heater help
This was my first one. Questions:
The fresh air intake was not sealed at the unit as well as sloping away from the unit before it went up through the roof, problem?
Exhaust vent has "trap" installed to catch condesate, 2 lines, small one drains to a little plastic tub, big one loops around and has water in the line but doesn't go anywhere.
I think the answers are obvious, but take a look and see if you notice anything else.
Thanks,
demand-water-heater-help-img_9113.jpg   demand-water-heater-help-img_9116.jpg   demand-water-heater-help-img_9118.jpg
Scott Falvey
Clear View Home Inspections, LLC
Newbury, NH
NACHI#05051292
www.clearviewhomeinspectionsllc.com
Old 10/3/08, 9:44 PM
Barry Adair's Avatar
Default Re: On demand water heater help
Is that flue 0-clearance to the kraft paper combustibles
Properly secure NM in the background
This would be a suspect install with modified drain vent, clear vinyl tubing and Ziploc container...not to mention the previous moisture stained flooring...so what were your other concerns
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 10/3/08, 10:37 PM
Was there a pressure relief valve located about 6 inches down the hot water outlet pipe? If so, was it draining to the outside of the building?
If there was condensate coming down the flue, How long was the vent run? It should be no more than 25 feet in length. It might be that they didn't have a cap on the vent outside and rain tends to enter the vent opening.
Jeff
Old 10/4/08, 10:58 AM
Jeff
There is a TPRV as indicated however it was installed pointed at the wall another 6" away, no drain and nowhere to go.
Here is the stack.
Scott Falvey
Newbury, NH
NACHI#05051292
Client wants a new water heater adirienzo General Inspection Discussion 47 7/14/10 2:03 PM
Pentair Water Pool Gas Heater Recall Gary Reecher Inspecting HVAC Systems 0 1/4/07 8:15 PM
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 9:36 AM
TPR & Combusiton Air thejnicki Plumbing Inspections 16 9/18/06 8:55 PM
