Hey Guys-
Any of you seen a dielectric fitting burn like this? The owner reported that the water heater and all the fittings were replaced in 2009. The flue vented okay with the smoke test and the other fitting had no damage. Any thoughts as to the cause? Thanks. Kenny Rigler Home Inspections Hays, KS 67601 785-656-0272 |
| Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Make sure that there is proper combustion air provision when all doors are closed. Make sure that the vent is properly configured. Look for exhaust fans in the same area, etc. I would treat this as a high priority safety issue. Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
When I did the smoke test I made sure the water heater and furnace were both running and the smoke was pulled right out. The mechanical room was plenty large. Full basement that wasn't fully finished and the dryer was on the main floor. Only one small bathroom vent which was located on the complete other side of the basement. No whole house fan or other abnormal ventilation system in the home and the appliance vents were in good shape. Rigler Home Inspections Hays, KS 67601 785-656-0272 Last edited by krigler; 9/21/11 at 6:54 PM.. |
OK if you can't diagnose exactly why during the course of a home inspection. The evidence that a problem exists is right there in your photograph. Don't let the fact that it worked OK today prevent you from documenting that there has been an issue.
BTW: though I can't see it all, that doesn't look like a large area to be pulling combustion air from for both those units (50cf/1000 BTU), as I recall. When natural draft and induced draft appliances compete for combustion air, induced draft wins. Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX Last edited by cevans; 9/21/11 at 7:05 PM.. |
| Corroded QPEX Fitting | krigler | Plumbing Inspections | 3 | 2/14/11 4:30 PM |
| MJ fitting on ABS | rmisener | Plumbing Inspections | 3 | 2/27/09 5:36 PM |
| Dielectric question | rbrady | Plumbing Inspections | 4 | 8/11/07 6:42 PM |
| Dielectric Union? | jfunderburk | Plumbing Inspections | 33 | 6/25/07 7:51 AM |
| Flexible Fitting | inspector@carolina.rr.com | Plumbing Inspections | 4 | 6/9/06 8:05 AM |
