Old 1/18/10, 11:02 PM
gfitzgerald's Avatar
gfitzgerald gfitzgerald is offline
Please Note: gfitzgerald is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default dielectric union.
Over the years I have seen my plumbers doing re pipes for me use dielectric unions as well as brass nipples to join cooper to galvanized. I have never been called on the brass nipple. I am not sure it is per code or not. I had an inspection today that had close nipples and the ones I have had done used at least 3" nips. There was no sign of corrosion on the connection.
Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/18/10, 11:45 PM
Bob Elliott's Avatar
Default Re: dielectric union.
Interesting question.
Looking around at all the forums ,the talk is that brass is more compatible with steel than copper . Apparently there is still some electrolysis going on,though at a slower rate.
Found a galvanic chart for compatibility that demonstrates what I said.
As a code question it may depend on locale.
http://en.wikipedia.org/wiki/Galvanic_corrosion
Old 1/18/10, 11:53 PM
I guess I can't recall ever seeing a city inspector crawling under a house so maybe thats why it was never called out
dielectric union jcahill Plumbing Inspections 15 2/25/11 11:42 AM
Governor: Texas Can Leave The Union jmckenna1 Miscellaneous Discussion for Inspectors 9 4/17/09 10:23 PM
Is this dielectric? pwigle Plumbing Inspections 8 11/2/07 11:05 AM
Dielectric Union? jfunderburk Plumbing Inspections 33 6/25/07 7:51 AM
Petition to the Minister for CMHC lewens Canadian Inspectors 7 4/24/06 4:53 PM
