I ran across this new construction direct vent water heater in a 7' high crawl space and the installation is bothering me because the drain pan is setting on a dirt "floor". I have researched today and cannot find a specific source of information stating it CANNOT be on a dirt floor in a crawl space?? What if a water pipe breaks and washes out the dirt underneath it? What about the pipes not being insulated?
Please share with me your wisdom before I complete the report!! Thanks Melissa |
Mellissa is there some sort of surface drain in the area. The TPR itself could fill the crawl. Also needs TPR drain piping, but to where I don't know.
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
You are right the TPR does not have a drain pipe and the contractor has not come and hooked up the gas either. There is no drain in the crawl space just a dirt floor with a plastic vapor barrier.
Thanks for your response Melissa |
| Water Heater Powered Vent Material | jevans | Plumbing Inspections | 14 | 3/13/08 10:53 PM |
| Gas water heater vent pipe? | pcloninger | Plumbing Inspections | 5 | 2/1/08 6:17 PM |
| gas water heater vent | cpennick | Plumbing Inspections | 15 | 5/20/07 10:05 PM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 13 | 1/11/06 9:53 PM |
