Bob Smith, Jr. is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hey inspectors!
Preparing for a DIY install on a water softener here in Phoenix Arizona. I need to replace a broken shut-off valve anyways, now would be a great time to include a softener. The unit is located in the garage, however I have no drain available for discharge. Typically water softeners will cycle about 40-60 gallons of brine once-a-week (or more), as part of their regeneration cycle. In my area, it's not uncommon to run these discharge hoses into the ceiling to drain them elsewhere (Laundry room basin, washing machine drain, etc) My Laundry room is out of reach for this project. My question is this, I have a bathroom about 25ft away. I was thinking of running the hose into the ceiling, and using the vent pipe for that bathroom. The drain hose has full household pressure, so it's not gravity sensitive. Of course, I'd include a P-Trap, check valve, and Air-Gap. I couldn't find any negative or positive comments for an approach like this. Any thoughts. Otherwise, I'm going to be forced to route it into my neighbors pool. Thank-you for your time! Last edited by Bob Smith, Jr.; 2/1/09 at 5:09 AM.. |
Bob, neighbor's pool it will have to be...see this thread
Don't let Mr. Kelly catch you doing this he'll write you up as should any inspector https://www.nachi.org/forum/f22/vent...te-lines-8425/ ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
| Pellet stove help | chellickson | General Inspection Discussion | 23 | 8/19/10 1:23 AM |
| Dryer vent & PVC discharge | dmacy | Inspecting HVAC Systems | 3 | 9/14/07 7:30 PM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 5:22 PM |
