Someone let me know if this installment is good. Dishwasher drain line is coming in from the bottom of the drain below the P trap. PLease describe which is the proper way. Thanks guys.
| Need a home inspection in Illinois? Check out InterNACHI's listing of Illinois certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I would say not correct. No air gap visible to me, unless it is out of the frame. Hard to say why they ran it after the trap as well.
That is wrong.
Must be after the trap otherwise the gas can enter via dishwasher possibly and the hose needs to be mounted up as high as it will go for a reverse trap also to help prevent water from the sink from contaminating the DW if it backs up.. An airgap is the preferred method though not supplied often. www.chicagopropertyinspection.com www.elliotthomeinspection.com www.chicagolandhomeinspection.com www.homeandcondoinspector.com www.homeandcondoinspection.com http://www.homeinspectorpro.com/ (Report Software) Bob Elliott http://www.chicagolandhomeinspector.com/ Last edited by belliott; 2/16/10 at 7:14 PM.. |
There is also an S-trap.
I was thinking of sewer gas and going backwards. OH the he-l with it (thanks) |
Gotcha Bob, just wasn't following along for a moment there!!
Yes it's wrong. Agree with above.
Bill Emelander Professional Edge Home Inspection Grand Rapids and all of West Michigan NACHI #03111914 www.proedgehi.com |
Thanks guys. So it is wrong the dishwasher should be connected above the P trap and there is an 'S' trap also. Right?
Correct.
In your pic there is no p trap and yes it should be above the s trap.
sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
"Should be connected to the house/building side of the trap" is how I would say it.
Anyway, the non vented "S" trap in itself is illegal. |
Last Update: 9/14/2006 PLUMBING AND MECHANICAL INTERPRETATION MANUAL CODE: 2003 IPC, IRC DATE: CODE REF: IRC Section 2717, IPC 802.1.6 9/14/2006 SUBJECT: Air Gap for Dishwasher Question: Is an Air Gap required for domestic and dishwashing machines. Answer: I-codes state that a dishwasher may drain through a deck mounted air-gap fitting or the drain line may be attached to the under side of the counter before connection to the disposal or drain. From 1991 the codes have required a deck mounted air gap fitting on the drain line of a domestic dishwashing machine to protect the water supply and to prevent the contamination of the contents of a dishwashing machine. With the adoption of the 2003 I-codes the local amendment was overlooked and therefore it appears from these sections that a deck mounted air gap on the discharge drain of a dishwashing machine is not required. However, Section 2902.2.1 of the IRC and IPC 409.2 states "Air gap devices shall be incorporated in dishwashing machines …’ These sections address the protection of the potable water supply. When an approved deck mounted air gap is installed on the discharge piping system from the dishwasher it prevents waste water from back-flowing in the reservoir of the machine. Thus preventing the potential contamination of the potable water supply. The IPC Commentary states that the looping of the drain hose is to minimize the waste flow back into the dishwashing cabinet. However, by the use of a deck mounted air gap on the discharge line it will eliminate the potential for any waste water to back-flow into the machine. Thus providing positive protection for the contents of the machine and the potable water supply. In an effort to ensure that the potable water supply remains protected in the event that a backflow occurs between the garbage disposal and/or point of connection to the drainage system. The plumbing contractor will be responsible for providing protection of the potable water supply in one of the following ways. 1. Backflow protection installed on the potable water supply. (PBV) The PVB must be used when a deck mounted gap is not installed on the discharge piping from the dishwasher. 2. Dishwashing machine to be installed has an approved air gap on the water distribution system of the washing machine. (Must be visually verified to be in compliance with Table 2902.2.1 IRC or Table 608.15.1 IPC) 3. Installation of a deck mounted air gap fitting or a device similar on the discharge line from the dishwasher to the point of connection to the drainage system will provide equivalent protection the potable water supply and contents of the dishwasher. Note: With the adoption of the 2006 I-codes the deck mounted air gap on the domestic dishwashing drain line will be added to the amendments.
NACHI #03120124 www.aplushomeinspections.net Proundly Serving S.E. Wyoming & Western Nebraska "Learn from the mistakes of others, Life is to short to make them all yourself" |
| Can I forego installation of an airgap with my Kitchenaid dishwasher? LA City | Jill Anderton | Plumbing Inspections | 6 | 9/21/08 8:12 AM |
| GE Dishwasher Recall | bwiley | Interior Inspections | 1 | 5/16/07 4:14 PM |
| Maytag recalls dishwashers. 135 reports of dishwasher fires. | gromicko | Interior Inspections | 2 | 2/5/07 8:07 AM |
| I smell rotten eggs. | rbracewell | Plumbing Inspections | 22 | 1/15/07 4:09 PM |
| Exploding Dishwasher | mbledsoe | Plumbing Inspections | 8 | 2/28/06 7:13 AM |
