Old 3/4/08, 5:42 PM
William J. Decker's Avatar
Default Dishwasher and disposer rules
Is it just in Illinois that dishwashers are not allowed to be drained to disposers, or is this the case with the national codes?
Any idea as to the reason, for both?
Thanks;
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 3/4/08, 5:50 PM
Default Re: Dishwasher and disposer rules
first time I have heard of that.
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 3/4/08, 5:52 PM
Christopher Currins's Avatar
It must be Chicago...
Connect the dishwasher tube to the disposer. Make sure Step 6 is complete.
Christopher Currins
Certified, Licensed
Old 3/4/08, 6:02 PM
No, Chris, it's both in the Chicago code and the Illinois state code. Not allowed in Illinois.
Will Decker, CMI
Old 3/4/08, 6:11 PM
Will, my plumbers have told me that the State of Maine new plumbing code changes also says that you can no longer drain the dishwasher in the pig.
Mine is hooked up to the pig and there it will stay.
So how do we call it now? Leave it alone? I think if it is functioning fine, we should.
What do you think?
Sounds like a Code issue and how it will get enforced by the AHJ's.
Marcel
Old 3/4/08, 6:11 PM
Bob Elliott's Avatar
I doubt it would be national code Will.
This bothers me more.
it was not even straped
Old 3/4/08, 6:15 PM
Attachment 19186
Bob, never seen one like that before, kind of neet. ha. ha.
Couldn't they have made everything chrome, looks so much better.
Marcel
Old 3/4/08, 6:16 PM
Attachment 19186
As long as there is an air gap, that's OK. Not good, but OK.
Will Decker, CMI
Old 3/4/08, 6:18 PM
James F. McKee's Avatar
still installing them that way here in Ohio Will...
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 3/4/08, 6:20 PM
Will, do you know how long this has not been allowed? I've seen this more times than not and after the local AJ has been there.
Christopher Currins
Certified, Licensed
Old 3/4/08, 6:21 PM
So I guess when that trap clogs up the neighbor down stairs are on there own.
I would rather see it in the disposial.
Long as you have the hose clamped above the bottom of the basin there is no worry about cross contamination if that is the reason for the local code
Old 3/4/08, 6:33 PM
No doubt. I find it all the time as well.
But the fact is that both the Chicago and the Illinois plumbing code prohibits it.
I call it out. Easy to fix.
I also call out plastic flex drain pipes. They are also not allowed.
Will Decker, CMI
Old 3/4/08, 7:23 PM
Russell W. Meyers Russell W. Meyers is offline
It's in the 1998 Illinois Plumbing Code, and I assume it pre-dates that issue. Sec 890.710 Food Waste Disposal Units .......Dishwashers shall not discharge into food waste disposal units. and again in Sec 890.770 Dishwashing Machines .... "Dishwashing machines shall discharge separately into a trap or tail piece of the kitchen sink and shall not connect to the food waste disposal unit." Like others, I've seen it for years and never called it out.
Russ Meyers
NACHI99040101
IL Lic. #450.000314
Old 3/4/08, 7:45 PM
Yes I always call out the plastic flex, But as long as the DW has the proper loop I never have for the disposal. Maybe I'll start, on newer homes anyway.
Thanks Russell..
Christopher Currins
Certified, Licensed
Old 3/4/08, 8:43 PM
Chris I would look at it this way.
If you miss serious roof damage is one thing
If you miss a hose connection thats not even leaking .....aaaaaaah
Acordian trap I think we all call out.
Dishwasher Air gap psiposs Plumbing Inspections 1 7/9/06 7:42 AM
Dishwasher drain set up..... tneumann Plumbing Inspections 13 4/6/06 11:40 PM
