I've never seen this configuration. Dishwasher drain connected just above the trap rather than the disposal. What are your thoughts on this setup?
Vince Santos
StepByStep Home Services LC (734) 748-9584 Providing Home Inspection Services to Southeast Michigan ITA Trained and Certified |
I have no problem with where it is connected, but wish it was bracketed to the underside of the counter,for a reverse trap.
I see this set-up quite a bit.
Not a big deal. |
Thanks for the help guys. Vince Santos
The high loop should only be called out if it's connected to the disposal.
The p-trap will take care of the waste connection. |
Wouldn't water or food being washed down the sink still have the possibility of entering the dishwasher drain particularly in the case of a clogged drain?
Vince Santos
StepByStep Home Services LC (734) 748-9584 Providing Home Inspection Services to Southeast Michigan ITA Trained and Certified Last edited by vsantos; 9/30/08 at 7:13 PM.. |
Yes, I'd call it out with no high loop.
Water always seeks its own level. Thats why some of the guys call out for the airgap devise. |
I prefer your arrangement to mine... Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
Vince ...that particular fitting is called a dishwasher tailpiece and was designed to be used just as shown...whether they are legal everywhere or not anymore is something i can't tell you...jim
Looks like the bottom of an old cast iron sink.
How was the porcelain holding up? Who needs shut offs ,eh Whats up with the black PVC though...is that a new fashion trend? |
Marcel hope that DW has a check valve. Did they have a plunger nearby?
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
Correct. It doesn't matter whether it's connected to a disposal or not, it should have a high-loop or air gap fitting.
The sink bottom was holding up OK and shut offs are not required on sinks in my area. They are required at toilet's and exterior hose bib's though. That black drain pipe is referred to as *Acrylonitrile Butadiene Styrene* ABS for short and is very common in my area; PVC is not. What I wanted to bring forward in my pic is that the dishwasher drain pipe is not trapped. Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
IMHO,
I would comment on the lack of a high loop, and that the DW drain line installed on the garbage disposal, helps keep it clean. tom |
| French drain tied into main drain | rwashington | Plumbing Inspections | 6 | 2/16/07 11:04 PM |
| Exploding Dishwasher | mbledsoe | Plumbing Inspections | 8 | 2/28/06 7:13 AM |
| nice dishwasher drain | jclark1 | Plumbing Inspections | 9 | 2/25/06 5:55 PM |
| Dishwasher Drain Line | msimmons | Plumbing Inspections | 9 | 1/19/06 11:27 AM |
