Old 5/27/11, 11:12 AM
ctasker ctasker is offline
Please Note: ctasker is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Dishwasher question
Hey all, had a question, was there a specific year when dishwashers were required to have a built in back-flow device installed, also, with that style dishwasher, does the waste discharge line still have to rise up and fasten to the underside of counter, have been seeing some new installations where the discharge line is almost direct (no loop or fastening to underside of cabinet) thanks, PS, fairly New Construction.
Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/27/11, 11:36 AM
Bob Elliott's Avatar
Default Re: Dishwasher question
They are required to have an air gap.
Recommend an air gap or high loop to prevent bacterial infection.Only a air gap is acceptable by code however.
Old 5/27/11, 11:49 AM
Thanks bob for confirming the loop, still stuck on the air gap thing, I do not always see those on newer installs, I assumed it was because the newer ones were equipped with an integral back flow device, with no need for air gap.
Old 5/27/11, 11:52 AM
You would have no way of knowing that.Assume none do.
Old 5/27/11, 12:20 PM
Thanks Bob, I will just write up, no visible Air Gap, Discharge line should have loop. are most HI`s running full cycle of dishwasher, thanks.
Old 5/27/11, 12:21 PM
You are not required to check appliances in the SOP but to answer ,yes I do.
Old 5/27/11, 12:35 PM
Thanks bob.
Old 5/27/11, 12:41 PM
Joe Funderburk, CMI's Avatar
2009 IRC P2717.2 Sink and dishwasher.A sink and dishwasher are permitted
to discharge through a single 11/2-inch (38 mm) trap.
The discharge pipe from the dishwasher shall be increased to a
minimum of 3/4 inch (19 mm) in diameter and shall be connected
with a wye fitting to the sink tailpiece. The dishwasher
waste line shall rise and be securely fastened to the underside of
the counter before connecting to the sink tailpiece.
Commentary: Dishwashing machines may connect directly to the
drainage system and do not require an indirect connection
by drainage air gap or air break
. The direct
connection is acceptable, because the potable water
supply is adequately protected against backflow. This
section requires that the waste line be looped as high
as possible and be securely fastened to the underside
of the sink rim or countertop to minimize the potential
of waste backflow into the dishwasher unit (see Commentary
Figure P2717.2).
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 5/27/11, 12:55 PM
. The direct
Figure P2717.2).
Does that include when connected ted to a disposal?(did not think so)
They are required here.
Old 5/27/11, 2:03 PM
Christopher Currins's Avatar
Does that include when connectedted to a disposal?(did not think so)
PART 890 ILLINOIS PLUMBING CODE
Section 890.770 Dishwashing Machines
a) Domestic Dishwasher (Private Residence). When a domestic dishwashing machine drain line is connected to the house side of a trap from a sink, the drain from the dishwasher shall be carried up to the underside of the spill rim of the sink. Dishwashing machines shall discharge separately into a trap or tail piece of the kitchen sink and shall not connect to the food waste disposal unit.
Christopher Currins
Certified, Licensed
Old 5/27/11, 2:17 PM
But allowed in other states Chris.
Airgaps are required in Chicago.
This makes for a good general statement.
Airgaps are now standard equipment to assure a separation between
supply and waste water. It is advised that either an airgap or a high loop
be installed between the dishwasher and the waste connection
Old 5/27/11, 2:21 PM
I know. Chicago's in IL.
You said "Does that include when connected to a disposal?"
That also is not allowed in Chicago, or the other half of Illinois.
Christopher Currins
Certified, Licensed
Old 5/27/11, 3:03 PM
How about the poster of the thread?
Is Canada part of Illinois.
Old 5/27/11, 7:08 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
If he is in Canada then why did you post "Only a air gap is acceptable by code however." ? Are you that familiar with Canadian codes?
Stephen Stanczyk
Old 5/28/11, 12:50 AM
That is a side bar with Chris.He does well on his own, big brother.
Sump Pit/Pump Question Joey D'Adamo Plumbing Inspections 4 11/26/08 1:04 PM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Hydrogen Bomb DISHWASHERS rspriggs Miscellaneous Discussion for Inspectors 8 8/3/06 4:55 PM
Dishwasher question mmorgan Plumbing Inspections 3 4/6/06 12:09 PM
Exploding Dishwasher mbledsoe Plumbing Inspections 8 2/28/06 7:13 AM
