Is there any c*de that prohibits this? I can't find anything. New construction (commercial). Copper water supply, metal (galvanized?) wall studs.
| Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Found it.
IPC 308.3. "Hangers, anchors and supports shall support the piping and the contents of the piping. Hangers and strapping material shall be of approved material that will not promote galvanic action." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Good to know.
Shoot, I wanted to give a dissimilar answer...
snooze ya lose
I hope you didn't spend an hour finding this Code.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Any pipe or wire installed passing through metal studs should be protected and/or supported by these inserts;
![]() ![]() ![]() ![]() LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
You mean I can't use duct tape anymore! LOL
Depends on which Brand and how many layers Kevin.
Ok! let's do the math. You have a hot and cold copper water line. The cold line will be used more than the hot line. If we figure on 6 layers of duct tape/month of wear and the house lasts 50 yrs even though the steel studs will probably rust out first we still want to make sure it is safe for the next person buying the home.
6X12X50=3600 layers x 2 pipes times the amount of stud protection needed. I think it will be cheaper to buy the plastic protectors. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
For those interested in Metal Stud Commercial Methods for Steel Stud Framing.
http://www.steelframing.org/PDF/SFA_...uide_11-08.pdf LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Thanks Marcel. Great help.
Those are great. But you wouldn't need them for metallic cables.
That might be the case code wise Robert, but any commercial work I have been on, required the use of the inserts even with AC wiring.
It actually makes the installation easier for pulling the cable through the thin metal. Using the inserts also protects the AC from physical damage pulling through the metal edges of the studs. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Don't forget about the possibility of electrical shock pathway of travel through to the steel stud just like the rule of the metal siding having an electrical shock pathway from lightning.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 Last edited by kwood; 10/11/11 at 9:22 AM.. |
| question??? Metal roof sweating | mjohnson6 | Exterior Inspections | 6 | 2/16/08 12:45 AM |
| Interesting Question? | jmckenna1 | Miscellaneous Discussion for Inspectors | 9 | 11/25/07 1:13 PM |
| Plumbing vent Routing Question | kweiss | Plumbing Inspections | 7 | 11/1/06 9:57 PM |
