Is this a requirement in Southern Calif.
David |
| Need a home inspection in Alabama? Check out InterNACHI's listing of Alabama certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
All water heaters.
The Uniform Plumbing Code (UPC), section 510.5 says "In seismic zones 3 and 4, water heaters shall be anchored or strapped to resist horizontal displacement due to earthquake motion. Strapping shall be at points within the upper one-third (1/3) and lower one-third (1/3) of its vertical dimensions. At the lower point, a minimum of four (4) inches (102mm) shall be maintained above the controls with the strapping." Washington, Oregon and California are all seismic zones 3 or 4. At FAST, we use only the best earthquake strapping kits available. If you live in a seismic zone, earthquake strapping is a very important part of your water heater installation. http://www.seismic.ca.gov/HOG/waterh...g_08-11-04.pdf |
Almost.
All storage type (tanks) heaters require strapping - gas or electric. Tankless type heaters need not be strapped. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
it's a water heater right!
| flammable vapor ignition resistant | dbaucum | General Inspection Discussion | 35 | 2/19/08 1:42 PM |
| Water heater strapping in manufactured homes | ilpowell | Plumbing Inspections | 10 | 2/24/06 5:20 PM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 13 | 1/11/06 9:53 PM |
