These pictures are from the floor drain in the public rest room of my buddies auto shop. As you can see the drain cover is simply resting on the drain and is not secured. The problem of securing it appears to be the cast iron has degraded to the point that it would be difficult if not impossible to screw the cover in. (The tiles can be trimmed back farther. They were left this way to give this "cover" something to actually sit on.)
Are any of you aware of a procedure or product that could be used to repair this? I'm sure he'd rather not jack hammer out the drain? Thanks Mark Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. Last edited by mnahrgang; 11/23/08 at 3:13 PM.. |
I would try a bottom tap make a new set of threads and go to the next size up screw.
...or maybe, drill out the hole and use a plastic or lead anchor to screw into.
Mark.
Clean it up. Try tapping it in a different spot. If it is all corroded and won't hold no choice but to break the floor. Gerry Pallotta Alota Home Inspection Services www.alotahomeinspect.ca Greater Toronto Area Home Inspector Mississauga Home Inspector |
I would just clean it up as much as I possibly can and simply epoxy it back on.
I would use a telephone
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Although, I agree with Bruce I would clean it and tap in new holes. I've done it.
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
