Sad situation today. Arrived on site and the property was wet to the core. So much in fact there were water drops an the ceilings and paint throughout was bubbling and sagging like melted wax. The attic sheathing was shiny with frost.
I'm not sure who turned the water on but from what I gathered it may have been a neighbor who came out to the property a few days prior to turn on the water for my client. It was also mentioned that the property may have not been properly winterized. Unfortunately the person who turned the water on did not perform a pressure test first to see if the lines would even hold pressure. And to top it off once they turned the primary valve at the floor it was rusted and would not turn off again. To make things even worse they could not find the main outside and had to leave the water running for some time, I don't know how long. The driveway had to be broken up to locate the main so they could turn the water off. This is a good example why home inspectors should never turn water on at a property unless you know exactly what you are doing. Turning water on prior to a pressure test is just asking for trouble. Vince Santos
StepByStep Home Services LC (734) 748-9584 Providing Home Inspection Services to Southeast Michigan ITA Trained and Certified |
Worth repeating.
Bobby Hamilton Bloodhound Home Inspection Services Youngstown Home Inspection Austintown Ohio Home Inspection Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
I do not and this is a great example of why. Thanks for sharing Vince.
Wow Vince again you came across a duzzy lol. I haven't in the past and certainly never will after seeing this aftermath.
Bill Boerner STL Home Inspection Services LLCServing St. Louis/Surrounding (314) 805-2137 office@stlhomeinspector.com http://www.stlhomeinspector.com Residential, Commercial, Radon, Termite, Lateral Sewer Scopes |
R.E. Rep. called me yesterdaystating that the home on Sat. has been winterized and I should call the other "person of interest" before the inspection to learn how to turn it back on so that I can inspect it "properly". After a brief but long pause, I said that I would not turn anything on but would get with the other person and have them turn it on.
John J. Passailaigue Jr. NACHI05062580 Auburn Home Inspection Auburn, Alabama WAR EAGLE!
I would have told the agent that that is his/her job (period!) Robert Newland Tyrone, GA 30290 NACHI05101290 http://www.CertifiedHI.com http://www.HomeInspectorTyroneGa.com Home Inspection Reports Powered by: HomeGauge eServices Last edited by rnewland; 1/6/09 at 11:28 AM.. |
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
I don't and your post is why.
It only takes one like that to mess up your biz for a long time. |
I do not--and was once told by the buyer's agent that it would be OK for me to turn on the water--water meter removed (left on the floor of the basement)...I inform the the agent it is the responsibility of the SELLER or his agent to have the utilities activated--not me, not the buyer, not the buyer's agent, not the neighbor, not no one, not nohow.
Then I get a call from the seller's agent..she says (among other things), "What kind of inspector are you, anyway?!?!" I reply, calmly--"A damn good one, Ma'am. It is my job to inform my client and also to PROTECT my client." ![]() Protect you client??--from who?" "You." Then I get a call later from the buyer's agent that the house will be de-winterized and the utilities will all be on. "Thank you very much. I appreciate your help", says I. "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
I've come to expect that I am expected to operate water main valves. It's almost like there's no question that I will just simply turn the water and gas on like it's the norm for inspectors to do this. Vince Santos
You have to train them on your business procedures. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
| New Washington Legislation Submitted | gdomagala | Legislation, Licensing & Legal Issues for Inspectors | 294 | 2/10/08 1:20 AM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 13 | 1/11/06 9:53 PM |
