Well?
rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
Probably not as often as I should.
Yes, every time.
Nope...
I flush and take it off during.
No, here in Ga., we use the bottom part of the toilet, except during family reunions.
Just if I need to verify the age of the home.
Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
Depends on where I'm at. Home? No. Inspection? Yes, but only after the flush has started. I used to take it off before flushing, but then a flushing mechanism broke one day and sprayed water everywhere before I could get the lid back on. Now I can remove the lid carefully, and if water is spraying everywhere, I don't have to take it all the way off.
Why??
What do you see other than water going down?? Sounds like just a show for the client What am I missing that would be seen by looking at just the flush?? I know that this was in HI 101 but I was asleep Please help rlb |
Nope....Because if you remove something that shouldnt be removed (based on the SOP) you would then be asked why you did not remove a FPE panel that had spark marks all over the cover. just my opinion
I don't remove every toilet lid. Only if I sense problems.
I can recall one house where I lifted the toilet cover and (low and behold), I spotted a bag of white powder tied to the flushing mechanism. I simply showed the listing Broker and she gasped when she looked at what I was pointing at. A bag of white powder...hmmmmmmm. |
Powdered sugar. Great with biegnets in the French Quarter in New Orleans.
I only lift the lid if I sense a problem. If all appears as normal, no lifty-no liddy.
| Expansion tank immediately downstream of main shut-off? | pcoulter | Plumbing Inspections | 11 | 1/30/08 12:00 PM |
| Wow | fduemig | Miscellaneous Discussion for Inspectors | 4 | 6/13/07 8:00 AM |
| Oil Tank in Basement Bedroom! | csteele | Inspecting HVAC Systems | 18 | 10/23/06 8:25 AM |
