Old 6/1/10, 2:31 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is online now
Default How do you think, how would you say it
Water heater vent, out the basement wall, attached with binding straps
do-you-think-would-you-say-gedc0030.jpg   do-you-think-would-you-say-gedc0031.jpg
Need a home inspection in New Mexico? Check out InterNACHI's listing of New Mexico certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/1/10, 4:58 PM
Jeffrey R. Pope's Avatar
Default Re: How do you think, how would you say it
The termination should be above the roof line for starters. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/1/10, 5:16 PM
Brian E. Kelly's Avatar
add in improper support and clearance.
Old 6/2/10, 11:24 AM
Jim Kolke's Avatar
Jim Kolke Jim Kolke is offline
Mike~
I'm a licensed plumber and owner of a plumbing company in Chicago and our code doesnt allow ametal termination on the side of home. You can use a high effeciency unit with blower motor water heater and install pvc to side of home. In fact that is exactly what the specs call for. Jeff is definitely right about that application. It needs to go above the roof. Your areas code will dictate. In plumbing the local area supercedes all federal codes. Generally they are much stricter. Contact me if you need more help.
Old 6/2/10, 3:46 PM
Thanks Jim, I appreciate your willingness to help.
I had never seen a direct vent go out a foundation wall like that. (power vents only) I don't have any narratives for it. What I ended up doing is noting that the vent had improper clearance and support and recommended repair. I used a graphic from the NACHI library as a reference.
Old 6/2/10, 6:01 PM
David A. Andersen's Avatar
If closer than 8' from the wall, it must extend 24" above the roof.
BPI# 5015804
Old 6/2/10, 8:22 PM
Jim Kolke's Avatar
Mike ,Dave~
Those are both awesome. I love the library. I use quite a few of the graphics for my blog service.
Old 6/2/10, 10:30 PM
Nick Gromicko's Avatar
Smart. The www.nachi.org/gallery/ is under-utilized for marketing purposes.
Find a Home Inspector
Old 6/3/10, 8:43 AM
Nick, I am just starting to use these as illustrations of proper installs inside my reports. Thanks for a VAST graphic library with Lots of uses.
Old 6/3/10, 11:15 AM
Joshua L. Frederick Joshua L. Frederick is offline
Also keep in mind - kids playing around a hot vent pipe.
