Old 9/11/08, 1:20 PM
Nick Gromicko's Avatar
Default Does anyone call out CSST in high lightning areas like Florida?
How does an inspector spot ungrounded CSST lines?
Find a Home Inspector
Old 9/11/08, 2:22 PM
Jeffrey R. Pope's Avatar
Default Re: Does anyone call out CSST in high lightning areas like Florida?
The proper bonding and grounding of CSST can be difficult to confirm for a Home Inspector. Depending on the LDZ designation of the city/town, the requirements will differ.
It's best just to defer to manufacturers requirements, and make home owners/buyers aware that there may be required uprgrades for the bonding and grounding systems where CSST is concerned.
[you're not gonna try to sell me something now, are you? ]
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/11/08, 2:39 PM
We're going to be doing a NACHI.TV episode on it as most inspectors know nothing of it.
Old 9/11/08, 6:17 PM
mnahrgang's Avatar
Could someone refresh my memory? CSST?
Mark Nahrgang
www.HeyMark.info
Old 9/11/08, 7:18 PM
Michael Larson's Avatar
Corrugated Stainless Steel Tubing used for gas line.
It's very common in my area in the last few years.
Michael Larson
Hudson, WI
[/I]
Old 9/11/08, 7:25 PM
Michael R. Boyett's Avatar
Here are a couple of documents that describe the lightning & bonding issue:
Try this and This
Excellence in Inspections
Mike Boyett, TREC #7290
mikeb@capcityinspections.com
Capital City Inspections
Austin, Texas
(512) 577-2579
Old 9/11/08, 8:38 PM
mnahrgang's Avatar
That's right... I remember now. Thanks Mike.
Mark Nahrgang
www.HeyMark.info
Old 9/11/08, 10:10 PM
Shouldn't fault the manufacturers on this one. Great product. Pretty tough to expect them to have forseen the problem with it being too thin to carry a lightning strike.
Old 1/30/12, 9:02 PM
Tim Scarfe Tim Scarfe is offline
Please Note: Tim Scarfe is a non-member guest and is in no way affiliated with InterNACHI or its members.
You should all know csst has gone through a redesgn Trac pipe is now making counter strike to withstand lightning strikes no bonding required.
Old 1/31/12, 8:43 AM
Joe Funderburk, CMI's Avatar
Rarely used due to the cost. Most install the traditional yellow piping, which requires a bond.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 1/31/12, 8:46 AM
It's actually pretty easy to determine whether or not the system is bonded. The bond has to be to solid steel piping, and connected to either to the main ground rod or to the main ground bus. If I don't see a GEC run from near the meter to either of those locations, I assume the system is not bonded and say so in my reports.
Theodore Roosevelt
Joe Funderburk, CMI
Old 1/31/12, 6:05 PM
Bruce A. King's Avatar
Bonding is required in most areas for all gas piping.
Additional bonding is not required for counterstrike.
Some elecricians are adding the additional bond anyway during construction. They are smart to do this.
The counterstrike is not new, its been around for at least 5 years.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 1/31/12, 6:11 PM
Nick, you need to make sure the video uses the correct terminology.
Don't use "ungrounded" use "not bonded" or "no additional bonding".
Also, every one of these CSST threads has someone that does not know the difference between additional bonding and regular bonding.
All gas pipes must be bonded and already are through the gas furnace cabinet to the 15 amp branch circuit equipment ground. The gas pipe bonds itself through the furnace's valve which is connected to the cabinet. This is the weak bond that was found to be ineffective so they started requiring an "additional bond".
The newer code about "additional bonding" is the one we can easily inspect since it is a large wire and clamp to the main gas pipe to the meter, main panel or GEC.
704 301-3207
Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/31/12, 10:37 PM
Cameron C. Anderson Cameron C. Anderson is offline
CSST gets used most often as a short run in my area. The black iron will stop below or near the fireplace and the then the CSST will continue up. If there is no bond on the visible run, it's not bonded in my report or it needs confirmed. I've seen one house in eight years with a proper bond on CSST, but it only appears a few times a year.
Cameron Anderson
Bachelor of Architecture, U of I, Urbana IL
Illinois Licensed Inspector
www.aaintegrityhomeinspection.com
Liability question jcahill Legislation, Licensing & Legal Issues for Inspectors 30 8/24/08 4:10 PM
Does anyone know anything about corrugated stainless steel tubing (CSST)? gromicko Structural Inspections 5 9/28/07 6:24 PM
