Old 4/29/07, 1:55 PM
rmccullough rmccullough is offline
Default Does this bath setup NEED a vent fan??
I was out and about and ran across this. I was wondering if this type of bath setup NEEDS a vent fan?
It is a little close to the living room with the TV right there an all. So to direct the exhaust "gases" away I am wondering, vent fan or no vent fan, and then which way would you suggest?
Thanks for your help in advance guys and ladies..
PS.. I would write up the stairs to the toilet though,, it needed a HANDRAIL IMHO
does-bath-setup-need-vent-fan-100_0739.jpg   does-bath-setup-need-vent-fan-100_0740.jpg   does-bath-setup-need-vent-fan-100_0741.jpg   does-bath-setup-need-vent-fan-100_0742.jpg
Old 4/29/07, 2:01 PM
Jeffrey R. Pope's Avatar
Default Re: Does this bath setup NEED a vent fan??
Certainly doesn't appear to be ADA compliant. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/29/07, 3:11 PM
phinsperger's Avatar
Be sure to check for moisture around the tub. I'm betting you will find some.
Old 4/29/07, 7:26 PM
James F. McKee's Avatar
I see no window so here in ohio that bath needs a fan....
Old 4/30/07, 2:29 AM
jbreazeale jbreazeale is offline
Please Note: jbreazeale is a non-member guest and is in no way affiliated with InterNACHI or its members.
Did you check the effluvium field for that one?
Old 4/30/07, 3:09 AM
jhugenroth jhugenroth is offline
Please Note: jhugenroth is a non-member guest and is in no way affiliated with InterNACHI or its members.
Did you check to see if that stump is hollow?
Old 4/30/07, 6:38 AM
David P. Valley's Avatar
Someone's bored....
Old 4/30/07, 10:00 AM
Barry Adair's Avatar
If that's a real cast iron Classic Roll Rim Clawfoot Bathtub
You may have left the price of a few inspections sitting in that field.
Were tell selling it for $10?
These are a real pain in the arse to move but well worth the investment for resale. One mans trash anothers treasure.
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 4/30/07, 10:04 AM
James H. Bushart's Avatar
I wouldn't want to be sitting there when the squirrel returned to retrieve his nuts...
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 4/30/07, 10:05 AM
Mark A. Timpani, CMI's Avatar
Mark A. Timpani, CMI Mark A. Timpani, CMI is offline
very nice
"Be Proud of Your Home, Go With Pride!"
'Not just a Home Inspection, but an Education'
Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties.
Old 4/30/07, 10:37 AM
waksell waksell is offline
Obviously the window is stuck in the open position. Id write up the window.
Old 4/30/07, 12:42 PM
dchew dchew is offline
Where's the hot water bidet?
Old 4/30/07, 12:52 PM
Steven E. Wiegner Steven E. Wiegner is offline
Send a message via AIM to swiegner
now thats a throne
Gas and oil hot water tank and Boiler Share Vents hvanderbeek Miscellaneous Discussion for Inspectors 8 1/25/07 5:22 PM
Bath Rm Vent djames2 Interior Inspections 5 11/26/06 1:27 PM
