Old 2/18/09, 12:21 AM
James R. Szczesny's Avatar
James R. Szczesny James R. Szczesny is offline
Default Does this trap look kosher?
This trap is to a tub, turns down into the y fitting pretty quick.
J.Szczesny
4 Seasons Home Inspections
Washington State Inspector # 711
800 5th Ave #101-385
Seattle, Wa 98104
(206)391-0285
online @ www.4seasonsinspects.com
email @ info@4seasonsinspects.com
toll free cal @ 866-512-9972
"For the best protection,
get the right inspection"
Old 2/18/09, 6:53 AM
Jeffrey R. Jonas's Avatar
Default Re: Does this trap look kosher?
Looks okay from here, but I'm all the way over in Minnesota
Old 2/18/09, 12:11 PM
mnahrgang's Avatar
Looks like the equivalent of an S trap to me.
Mark Nahrgang
www.HeyMark.info
Old 2/18/09, 12:22 PM
Michael Larson's Avatar
It is not an S trap in any way. Sorry Mark. Look again.
Michael Larson
Hudson, WI
[/I]
Old 2/18/09, 1:16 PM
Michael R. Boyett's Avatar
I agree Mark...the length of horizontal arm connecting to the wye should be at least 2x the diameter of the pipe. It doesn't appear to meet that requirement to me.
Excellence in Inspections
Mike Boyett, TREC #7290
mikeb@capcityinspections.com
Capital City Inspections
Austin, Texas
(512) 577-2579
Old 2/18/09, 1:24 PM
Attachment 26960
You raise a good point Mike.
I don't see how it's an S because the vent is above the wye..
Michael Larson
Hudson, WI
[/I]
Old 2/18/09, 1:30 PM
Stephen W. Stanczyk's Avatar
Those drawings don't show the same thing as the photos. It appears the actual photos show the trap joined via a wye connection with either a vent stack or other waste line. If it is a vent stack, there would be no S trap effect since the vent would allow the water to flow without creating the suction caused by a true S trap. Now if that is connected to another waste line, there could be problems. With a tub draining, there could very well be a strong enough and long enough draw on the upper waste pipe to drain an upper P trap.
So what was it? A vent stack or waste line?
Stephen Stanczyk
Old 2/18/09, 1:39 PM
Chuck Evans's Avatar
I'm with Mark. Trap arm is too short.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 2/18/09, 1:47 PM
Brian E. Kelly's Avatar
It is too close to an open J-Box.
Old 2/18/09, 6:23 PM
I've just never see the caveat of 'if the vent is close then the horizontal arm doesn't need to meet the 2x dimension'. Makes sense though. We need master plumber to call this one I think.
Austin, Texas
(512) 577-2579
Old 2/18/09, 7:34 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
Did everything drain correctly?
Old 2/18/09, 8:03 PM
jkogel jkogel is offline
The question is Does it SMELL kosher? If that stack is vented, it probably drains ok without siphoning out the trap. I'd just mention possible amateur workmanship.
John Kogel
Old 2/19/09, 12:13 AM
well I believe it smells bad! it is equal to a s-trap. vented or not the possibility of it siphoning is there. This is a new contsruction inspection. pre-drywall no water on yet to test. but city inspectors missed it!
J.Szczesny
Seattle, Wa 98104
(206)391-0285
Old 2/19/09, 1:59 AM
If that is an open vent above the wye there is no possibility of siphoning. Siphoning is cause by the pipe being completely filled with water and the drain line, being longer and holding a greater weight of water, pulling the lesser weight of water from the trap. If there is an open vent, the required vacuum for siphoning does not exist.
Stephen Stanczyk
Old 2/20/09, 2:49 PM
thanks stephen and all
J.Szczesny
Seattle, Wa 98104
(206)391-0285
Trap Primer Question jallingham Plumbing Inspections 5 2/15/08 7:36 PM
Potable Water Line to Trap jcooper2 Plumbing Inspections 9 11/1/06 12:17 AM
Negative angle trap arm issue rlind Plumbing Inspections 4 4/14/06 11:00 PM
Grease Trap / Drum Trap David White Plumbing Inspections 1 2/7/06 5:41 PM
