Unit was installed on the side of the house....The unit was turned on
but was not working...like the pilot had been blown out by the wind. Which is making me ask the question...
| Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Lol.
JOKE RIGHT? |
No... need the truth. I usually see them in a metal enclosure.
![]() What does vent pipe connect to? Christopher Currins Professional Home Inspections In Edwardsville, Glen Carbon, Fairview Heights, O'Fallon, Godfrey, and surrounding areas of Southern Illinois We Make It Safer |
Eave....hardware attached to the eave....
We see nothing like that up here Dave....just can't keep that water from freezing in the winter time....
Dave, I did a quick search on a couple of mfg's istallation manuals and they both said they must be installed indoors. Looks like your picture has the base of a metal closet(?)
It looks very dangerous to me, in several ways.
clambert2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
It appears that there was a metal enclosure around it, the base is still in place. See it all the time in older areas here. Recommend they replace the enclosure
Ok back in and I will not even comment on the goofy thing past how it it takes to burn down the house.
Unlit pilot may be a blessing or is it now safe to have fire pits on the wall? |
I have never seen a non tankless made for exterior installation. I have seen small water heaters installed outside like this in warmer climates but most always they are in some sort of shed or closet.
Bob, To see a water heater on the exterior of an older home around here (So Cal) is very, very common. I agree not the best set up but very common. They make metal enclosures (that are crap) for such installations. Of the hundreds maybe thousands I have seen none are installed correctly, saw three last week. They can be installed outside here because our weather is much more mild than elsewhere in the country. |
I see them installed like this often at an old property, I don't believe there is anything wrong with it, they installed tens of thousands like that in the greater Phoenix area in the 50's and 60's, some people just replace them when they fail, but install them at the same location with no enclosure.
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Thermal Imaging InterNACHI 2007 U.S.A Member of the Year National Association of Commercial Building Inspectors and Thermographers™ |
So it is OK to have a flaming burner (gas) right up against a flammable siding?
Bunch of idiots would allow that. No gas water heater is allowed to be in contact with a wall even inside where wind will not fan a flame as here. That flex line looks very stressed |
If a type-B Vent is going through the eave with one inch clearance, what's the problem? It might be a Masonry Wall too, most older homes were built properly. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Thermal Imaging InterNACHI 2007 U.S.A Member of the Year National Association of Commercial Building Inspectors and Thermographers™ |
| Pool/Spa Inspection contract. | jdobbs | Florida Inspectors | 11 | 10/6/12 6:07 PM |
| Sulphur smell | bsmith | Plumbing Inspections | 2 | 6/6/08 8:32 PM |
| Water heaters in attics | phughes | Plumbing Inspections | 1 | 1/11/07 11:08 AM |
