Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
anyone have the different configuration drawings of a double sink into one trap setup. Came across a double sink with the t in the middle draining into the trap. Each sink had its drain line meet in the middle where the T was. Usually see the trap off to one side or the other. Kind of remember seeing something that this wasn't an ideal setup but can't remember why. thanks
If you have a picture it would make things easier.
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
Scott...it sounds like you are looking at a center outlet drain as opposed to the end outlet ...either is fine and normal, and which one is used is determined by where the termination point is at the wall....jim
| Slope of waste drain line. | mlong | Plumbing Inspections | 5 | 4/23/08 10:54 PM |
| Evaporator drain line | lfoster | Inspecting HVAC Systems | 3 | 7/18/07 9:35 PM |
| How turns can you have on a TPR drain line? | jlybolt | Plumbing Inspections | 8 | 6/10/07 10:35 AM |
| Double sink drain used on single sink | tneumann | Plumbing Inspections | 6 | 10/23/06 7:02 PM |
